Need Bios EC dump for FH52M LA-J891p
Tags: None
Re: Need EC dump for FH52M LA-J891p rev 1b
Acer Nitro5
AN515-55-56wh
serial NHQ7PEU00L0500E0B23400
no old bios backup ,because before engineer dont save itComment
bios and EC bios extracted from Acer site update ...Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
FREEZE FROM LAPTOP
TRY GUYS::::
bios extracted from Acer website update
DMI B2D000 - B2EFFF
KEYWIN 370000 - 37003FAttached Filesif you find these attachements useful please consider making a small donation to the site
FH52M LA-J891P Rev 1b TESTEDAttached Filesif you find these attachements useful please consider making a small donation to the site
hi i need bios dump for nitro an515-55-7012 fh52m la-j891p
hi i need bios dump for nitro an515-55-7012 fh52m la-j891pAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: hi i need bios dump for nitro an515-55-7012 fh52m la-j891p
Try this one,its the virgin bios from post #11 + your DMI (serial number) from your backup , the win key is from post #5 as it was missing in your backup.
D B2D000 - B2EFFF
W 370000 - 37003F
Re: Need Bios EC dump for FH52M LA-J891p
I dont have my original backup i dont think, i have the file i dumped before i flashed a different bios. Thats all i have,Attached Filesif you find these attachements useful please consider making a small donation to the site
Ok,try this bios . B.t.w. your backup was corrupt and the serial number is different to the one you posted.
Hello i need bios dump for
Nitro AN517-52-74V7
S/N: NHQ8JEV00601908C243400
Board: FH52M LA-J891P Rev: 1.0
I have attached my original biosAttached Filesif you find these attachements useful please consider making a small donation to the site
Bios extracted from the Acer website update
DMI B2D000 - B2F00F
KHEYWIN 370000 - 37003F
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
