HP 430 G8 Bios
  • palooza
    • May 2022
    • 10
    • uK
    HP 430 G8 Bios
    Hi
    Can anybody help with a HP 430 G8 BIOS
    Attached files from both chips are below
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    • Gadget & motorcycle addicted
    Re: HP 430 G8 Bios
    Originally posted by palooza
    Hi
    What's the problem? Bios password?
    Become a Badcaps supporter
    Thanks to all supporters.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12682
      Re: HP 430 G8 Bios
      Hi
      @Vesko356 , His bios corrupted.
      HP 430 G8 Bios (T85)
      If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
      Subscribe to support us. It only takes 1 minute:
      https://www.badcaps.net/settings/subscriptions
      • palooza
        • May 2022
        • 10
        • uK
        Re: HP 430 G8 Bios
        Bios has password on - is it corrupted to?
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Re: HP 430 G8 Bios
          That's why I asked him what the problem is, he says that the problem is the BIOS password but the laptop boots normally means that just the reading of the BIOS chip is bad, and in fact the BIOS binary in it is OK. This chip should not be overwritten to remove the password. So in this case only EC chip must be reflashed and this should solve the problem.
          • palooza
            • May 2022
            • 10
            • uK
            Re: HP 430 G8 Bios
            We did read and write the original bios and the laptop stopped turning on. This dump I gave you is the original file before writing it again to test. Is the bios now corrupt? Sorry fairly new to this. Do you have an EC file with no password?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12682
              Re: HP 430 G8 Bios
              The MX file has been corrupted. Regarding the password, Vesko356 helped you delete it in the remaining file.The problem is getting more complicated.
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Re: HP 430 G8 Bios
                And why?
                After you managed to smear all the picture, now the option is to program hoaca388's file at the bios chip, and in the EC chip the file I posted above.
                And next time ask first then act, not the other way.
                • palooza
                  • May 2022
                  • 10
                  • uK
                  Re: HP 430 G8 Bios
                  Thank you for all your help - I did it before to try out the tool and to see if it worked, too excited to try it i guess!
                  Anyway, I've flashed the two files I got told to and now the laptop just flashes orange on the charging light and nothing else.
                  Any ideas?
                  Just to clarify what i've done
                  1) Read both chips with CH341A
                  2) Uploaded here
                  3) Realised i messed up and jumped ahead
                  4) Erased and blanked using software and it says chip is blank
                  5) Wrote you're guys files back and then soldered back on to laptop
                  With help from https://winraid.level1techs.com/t/gu...ogrammer/32948
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12682
                    Re: HP 430 G8 Bios
                    Now here it is : You need to get your computer back up and running first ( the password problem will take care of it later ). Flash my bios file and the original EC file (the one with no password removed) and see the result.
                    • palooza
                      • May 2022
                      • 10
                      • uK
                      Re: HP 430 G8 Bios
                      Just trie this and still go the same issue, flashing orange light on charger not turning on
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12682
                        Re: HP 430 G8 Bios
                        Try and report
                        • palooza
                          • May 2022
                          • 10
                          • uK
                          Re: HP 430 G8 Bios
                          Try and report
                          It now powers on!
                          However when it turns on it now says there is an issue with the HP endpoint security controller, it also doesn't show any charging light
                          Any ideas?
                          Edit its not asking for a hp cloud management disable request
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12682
                            Re: HP 430 G8 Bios
                            Try to use Vesko356's EC file.
                            • palooza
                              • May 2022
                              • 10
                              • uK
                              Re: HP 430 G8 Bios
                              Hi, with that file I get a solid white charger light and doesn't turn on
                              It then turned on after 10 mins saying updated bios, then to saying it had a data mismatch so it's recovered
                              Now it's turned on with fan at full speed no lights
                              • palooza
                                • May 2022
                                • 10
                                • uK
                                Re: HP 430 G8 Bios
                                da0x8pmb8f0 Rev F
                                This it the board number, figured might come in handy
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12682
                                  Re: HP 430 G8 Bios
                                  Tried my best
                                  • palooza
                                    • May 2022
                                    • 10
                                    • uK
                                    Re: HP 430 G8 Bios
                                    Tried my best
                                    Thank you for trying, unfortunately it doesn't turn on with those two files.
                                    I read somewhere that if the CT code is missing it doesn't charge, its missing on the file where it works
                                    • Dan20701
                                      • Sep 2020
                                      • 211
                                      Hello all, I think I am in the right place EliteBook 430 G8, Can someone please remove the password.
                                      S:N , 5CG14328MC
                                      Model , DAX8QAMB8D1 Rev D
                                      Thank you.
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12682
                                        S:N , 5CG14328MC
                                        Thank you.
                                        Unlocked
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Deniz
                                          IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
                                          by Deniz
                                          Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
                                          I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
                                          I had the BIOS cleaned, but the issue was not resolved and there was still no image.
                                          Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
                                          After that, I tried to update the...
                                          01-27-2026, 06:56 AM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
