BBS MOD MxP APPLE BLACK BOARD SERIALIZER
  • Odeinkantar
    • Sep 2016
    • 5
    • Indonesia
    Re: BBS MOD MxP APPLE BLACK BOARD SERIALIZER
    Originally posted by Maxpower3
    *********** BLACK BOARD SERIALIZER ***********
    Blank Board Serializer is mod by MxP !! Enjoy !!!
    Setting serial number is too easy
    " Only for all Mac models 2009 to 2017 "
    This USB tool helps to:
    Change the Serial Number (SSN) or add a new Serial Number.
    It supports all type of Macs including MacBook, MacBook Pro, MacBook Air, iMac, Mac mini and Mac Pro (2009 to 2017).
    * Use RUFUS to create USB key with .img
    ** The process is as simple as booting the Mac from the USB tool, type a new serial number and confirm.
    --------------------------- WARNING--------------------------------------
    Some letters are prohibited from origin program by Apple "AEIOUBSZ". (look pics)
    I authorized them in this version for test.
    Don't Use if you don't know
    This is not a crack of MacUnlock version, just this inspired me and I searched
    Just need a little usb key
    Archive Size: 389*Mo /.img Size: 494*Mo
    • Test12344
      • Oct 2023
      • Dallas
      Rufus for Mac Alternative: balenaEtcher
      • louisdons
        • Sep 2021
        • mexico
        CAN YOU SHARE THE FILE .IMG
        • kevingill
          • Jun 2013
          • 152
          • England
          It's in post #2
          • Testing123456
            • Oct 2023
            • Dallas
            Does it remove Mdm Lock permanently?
            • Adsiddiqui
              • UAE
              #26
              BBS bootable usb which models compatible with year.
              please tell me. Thanks
                • 20737
                Read post 1
                • logic4
                  • Mar 2017
                  • indonesia
                  #28
                  how to make bootable usb with rufus? the file in post2 is .zip,,
                  • HSBunlock
                    • Mar 2021
                    • 30
                    • UK + PAK
                    #29
                    Dear Sir how to create bootable USB, i download this file
                    (MDM2009-2017.zip) but its not supported on rufus, even i change to IMG, but still not support. can you help me this this please​
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1222
                      • France
                      #30
                      Extract rar and try like this with img
                      Click image for larger version  Name:	Nouveau Image bitmap.bmp Views:	0 Size:	1.45 MB ID:	3225816
                      • HSBunlock
                        • Mar 2021
                        • 30
                        • UK + PAK
                        #31
                        brother this model supported?, A1989 ?
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1222
                          • France
                          #32
                          no, I don't believe
                          • HSBunlock
                            • Mar 2021
                            • 30
                            • UK + PAK
                            #33
                            no, I don't believe
                            and dear thanks for help, i do with hardware via change SN on bios chip, one more help, i want to change SN Macbook M1, the serial inside in EMMC (Nand Chip)? becuase i find on bios chip not found in Bios chip.
                            • Alex Karchagin
                              • May 2024
                              Can you tall me how i can use this, i just copy this files to my usb flash and it works with 90% of macbooks but not all, what i should do?
                              • Jtzabala
                                • May 2011
                                • 14
                                • COLOMBIA
                                #35
                                Ok, friend, I'll try it and tell you, thanks for the contribution.
                                • Jtzabala
                                  • May 2011
                                  • 14
                                  • COLOMBIA
                                  #36
                                  • sergiobtnrs
                                    • Sep 2023
                                    • spain
                                    #37
                                    I have a 2020 MacBook Air (M1 chip) which does not have a serial number and has a loop in 'Diagnostics Loader', is there anything that can be done?
                                    • kevingill
                                      • Jun 2013
                                      • 152
                                      • England
                                      #38
                                      This software won't help sadly
                                      • Peterpan1234
                                        • Apr 2024
                                        • Czech
                                        #39
                                        is it possible to remove the iCloud activation lock on an a1708 MacBook with the serializer?
                                        After change the serialnumerb it should be possible to activate or?
                                        best regards
                                        • kevingill
                                          • Jun 2013
                                          • 152
                                          • England
                                          #40
                                          Yes, it will work
