l50-b-2dj no image
  • NPIRES
    • Oct 2012
    • 20
    • Portugal
    l50-b-2dj no image
    Hello all, sorry for the long text, but i'm trying to describe it the best i can.
    I've a Toshiba l50-b-2dj (board dablidmb8e0 rev:e) with the following fault : turns on, backlight on, no image, keyboard works, hdd spins and loads windows. After a minute or two, turns off. After using intel easy clean me on the bios, machine would have the same symptoms, but instead of shutting down, windows login screen would come up, and machine worked fine. Intel and Amd vga were detected and no question marks in device manager. Machine was working fine, across several reboots, appart for the no image until login screen, and the impossibility to enter bios, since there was no image at that point.
    Tried another bios from the forum and went back to point 1. Tried the original cleaned image and stayed in point 1 again, i.e. shutdown when the login screen should appear.
    Tried another image for another l50-b and this time i had image on boot. Since it was the wrong bios, no hdd or usb were detected. Looking at bios setup, noted it was set to CSM. If i change that to uefi, i again loose image on boot.
    Can someone please have a look at my original bios ?
  • hoaca388
    Badcaps
    • Jan 2022
    • 11607
    Re: l50-b-2dj no image
    Toshiba l50-b-2dj
    • NPIRES
      • Oct 2012
      • 20
      • Portugal
      Sir, you are my hero. Laptop now boots fine.
      • maviwec184
        • Feb 2023
        • 10
        • Portugal
        Hi, I have this exact problem:
        'working fine, across several reboots, appart for the no image until login screen, and the impossibility to enter bios, since there was no image at that point."
        But the model is 1U8.
        Can I use the same file shared here?
        I'm a complete noob, so how can I apply it in windows? Is it possible?
        • Focus2005
          HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
          by Focus2005
          Hello everyone.
          I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
          05-01-2025, 05:41 AM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
          by Vesko356
          08-11-2023, 03:27 AM
        • grimacelord
          Latitude E6530 - Trouble Extracting BIOS Image From EXE
          by grimacelord
          Hi folks,
          I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
          Service tag number for this model is: "JYDWYW1".
          Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
          I have tried:
          • Simply extracting with 7zip
          • PFSExtractor
          • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
          • Check Temp folder
          10-26-2023, 08:15 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
