Lenovo V130-15IKB LV315KB MB 17807-3M 448.0DC05.003M Bios version 8VCN17WW
hello ig_cat
i have the same laptop and i have a problem the laptop won't boot only the power and capslock lights keep on, the fan is also spinning.
this is because i did a bios update under windows 11 64 system.
i have tried all the bios dumps on this forum and none of them work, can anyone help me?
Lenovo v130-15IKB
Model: 81HN
S/N : R90T8EYL
MTM : 81HN00KUAK
MO : R90T8EYLR9N0B922300L
This is a backup after the BIOS was updated and there was a problemAttached Filesif you find these attachements useful please consider making a small donation to the site
Always added serial number .hello ig_cat
This is a backup after the BIOS was updated and there was a problem↵
https://www.badcaps.net/donateComment
V130-15IKB Laptop (Lenovo) - Type 81HN
i updated from lenovo support site with version 8vcn31ww.
i cant see anything via hdmi, and i have downloaded the bios you shared in another post on this site. nothing works.
Everything is still the same, the fan is spinning and the power and capslock leds are on.
i have also tried using a usb and copying the BIOS.cap inside, pressing fn+r but nothing happens.Comment
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
History:
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... - Loading...
