need bios ACER NITRO AN515-54
Re: need bios ACER NITRO AN515-54
here is the new bios extrected from acer support
dmi @ 370000-37069fAttached Filesif you find these attachements useful please consider making a small donation to the site
Please read the rules before posting.. Post your bios backup.You must post the laptop serial number SNID
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
Acer Nitro 5 AN515-54
MD# N18C3
Board # EH5VF-LA-H501P Rev1A.
S/N NHQ59AA002014116513400.
Good day all, can someone help me in extracting the EC from the bios file attached? I did go through the BIOS Guide, but the first pad area as described in the guide, is only 8kb on this file. The ENE KB9022 chip is 128kb so im confused. The original ENE chip seem to have died after a PCH failure (dead short from PU1101 supply side on the PCH). The PCH had been replaced but laptop still remains dead. The ENE was also replaced but need the EC file to program it.
Thanks in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
ECAcer Nitro 5 AN515-54
MD# N18C3
Hi. I have an Acer Nitro AN515-54, which when pressed on the power button sometimes it will switch on and sometimes it doesn't. I could also notice that when it is off, pressing any key on the keyboard will make the computer switch on for about 10 seconds and it goes off. Would someone be able to take a look at these dumps to check if there's anything wrong with it, as I haven't found anything wrong with the device, once it switches on it actually works with no issues at all. Many thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Hi. I'm very sorry for the lack of information and failure to obey the rules of the forum. Allow me to rephrase my last post.
Brand: Acer
Model: Nitro AN515-54 series
Model no.: N18C3
Serial no.: NHQ59SA004917160C3400
SNID: 91707118034
Motherboard Model No.: EH5VF LA-H510P
Rev: 1.0
I received this machine a few days ago. After the diagnostic this is what I noticed:
1. - Pressing the power button the device lights up, no image, fan spins. After about 10 seconds the machine turns off.
2. - Pressing again the power button will have no effect and the machine doesn't light up.
3. - Pressing any other key on the keyboard will make the device light up, again no image, fan spins. After about 10 seconds the machine turns off.
5. - Sometimes the machine turns on just fine, as if there were no issues.
6. - Motherboard analysis did not reveal anything unusual. Seems to be the first time that the device is being repaired, although, one can only assume.
I've done all the tests needed to make sure all peripherals and other components were in good working order, once the machine booted. Being that the issue seems to be happening at random and that nothing else seems to be a problem I decided to create a few dumps of the Windbound SPI chip, considering it could be a problem related to the bios itself.
I would like to ask if anyone would have the availability to verify this dumps, and maybe point out if this is the right lead I should follow to solve this issue that the machine is displaying.
Hope that this post follows the propper conduct of the forum. Thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
the laptop's bios is 16 MB, look for another bios chip on the card, make a copy of the content and write it with this..Hi. I'm very sorry for the lack of information and failure to obey the rules of the forum. Allow me to rephrase my last post.
Brand: Acer
Model no.: N18C3
SNID: 91707118034
Rev: 1.0
Every donation made will go towards server fees and maintenance costs.Comment
Hi, and thank you for your support.
I have done as requested and backed up the SPI chip with the mark "XMCQH128AHIG". After that I wrote the dump you sent me, but unfortunately the machine wont light up when pressing the power button, Also, pressing space or any other key used to make so that the keyboard backlight lighten up and fan spun, but now it also doens't happen.
I am leaving the dumps made to this chip, in case you'd like to have a look at it.Attached Filesif you find these attachements useful please consider making a small donation to the site
this is the virgin bios from the Acer website for the laptop with the SNID you posted..either you wrote the bios with errors, or the problem is not the bios...try to write the bios chip again but remove the chip from card, if you don't have this possibility, stick wires between the programmer and the chip....
I am leaving the dumps made to this chip, in case you'd like to have a look at it.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
ACER NITRO5 AN515-54-54W2
S/N. SNNHQ5VAA001913127AD3400
SNID: 91307569334
M/B LA-H501P REV 1.0
Hi all.
trying to update bios on above laptop.
Ive downloaded the bios from acer and after extracting the exe file it with 7 zip ive got a bin file which is 17.795kb. my bios dump is 16.384kb.
Im struggling trying to edit the new one. Can someone please help
Just to add,Ive tried using the file posted by peste and I get the same result as Umadbro.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello there, I messed up some settings from my bios and I ended up with the laptop bricked, this happened a few days ago. I tried with a clean bios from the Acer website but it didn't worked.
Model an515-54-57CR
SNID: NHQ59AL00R015014983400
snid: 01500527234
motherboard model: LA-H501P
I disabled both Dimm channels, so I don't know if that information could be useful, I most appreciate every help.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello, I need help to repair this Bios Dump, I replaced one of the mosfets that powers the CPU (it was shorted), now the 0,9v voltage is present (and all the others too) but I do not have an image, I have the doubt of the Corrupt bios,details below.Thanks in advance.
ACER NITRO AN515-54-50T7
S/N : NHQ59AL01A1151ADAC3400
SNID : 11510999634
PCB P/N LA-H501P Rev 1.A
did you try post #2 ???Hello, I need help to repair this Bios Dump, I replaced one of the mosfets that powers the CPU (it was shorted), now the 0,9v voltage is present (and all the others too) but I do not have an image, I have the doubt of the Corrupt bios,details below.Thanks in advance.
SNID : 11510999634
PCB P/N LA-H501P Rev 1.ADue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
you don't need the DMI information to start... if you wrote the bios correctly it should work... or you have another problem..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Surely this happened, thank you very much for sharing your knowledge, I had also flashed the VGA Bios (UV49) with the dump provided by another user without results, although the CPU maintains the voltage of 0.9v, perhaps it was damaged when the short circuit occurred in the mosfet, makes an attempt to start (consumption sequence after turning on) but finally remains at 1.17amp, no HDMI or LVDS signal. Again, thank you very much.
This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 04:10 AM
This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060,...09-07-2024, 03:10 AM
This specification for the Acer Nitro Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) boardview and Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz,...09-07-2024, 03:10 AM
This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full...09-07-2024, 03:10 AM
This specification for the Acer Nitro Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) boardview and Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz,...09-07-2024, 01:00 AM
- Loading...
