Request BIOS unlock for Dell E5570
  • infowire
    • Oct 2021
    Hello, I'm trying to unlock the BIOS password, i tried the https://bios-pw.org/ no go.
    My system number C94VPF2-6FF1
    Service Tag # C94VPF2
    Service code 26673781356
    Now need to locate the bios chip to read it, i assume i need to take the board out, anyone can give me advice where to look? I will post the bin as soon as i find it.
    I would like to learn what do you look for in hex to get it unlocked ?
    Thank you.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12269
    Re: Request BIOS unlock for Dell E5570
    Thank you.
    Change 6FF1 to BF97, you have C94VPF2-BF97 . try again.
    • infowire
      • Oct 2021
      It worked! how did you get that number from ? BF97
      • hoaca388
        Badcaps
        • Jan 2022
        • 12269
        The 6FF1 suffix is faulty, it is recommended to replace it with BF97
        • sanik131
          • Aug 2022
          • Netherlands
          I'm trying the same with system number:
          284QQC2-E7A8
          but it did not work. Is there also something i have to change or whatever to get the working master password?
          Tank you.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12269
            Originally posted by sanik131
            i'm trying the same with system number:
            284qqc2-e7a8
            Tank you.
            * for some dell codes press ctrl-enter, not enter, when entering code into the bios
            • sanik131
              • Aug 2022
              • Netherlands
              I have already tried to press ctrl/enter and it still wont work. And i also read here in another old Thread, that there is now free master pw generator for suffix-E7A8, is that (still) true?
              In this case, can anyone do this for me please? Or is it easier to manipulate a Bios Dump?
              Anyways, thanks a lot
              • hoaca388
                Badcaps
                • Jan 2022
                • 12269
                You must use a Qwety US layout keyboard.
                • elvirpa800
                  • Nov 2019
                  • 27
                  • Deutschland
                  Hello People
                  Can you please remoove Password from my bios dump
                  Its a
                  Dell Latitude E5570 with Amd Graphics
                  Mainboard is LA-C642P
                  W25Q128FVSQ
                • elvirpa800
                  • Nov 2019
                  • 27
                  • Deutschland
                  Originally posted by elvirpa800
                  Hello People
                  Its a
                  W25Q128FVSQ
                  Sorry my mistake
                  its a Dell Latitude E5570 Type no: P48F001
                  Service Tag 59HTSC2-6FF1
                  Board Nr : ADM80 LA-C642P
                  Rev 1.0 (A00)
                  AMD Graphics.
                  Tryed with Calculator But Wrong Pass Same with BF97 instead of 6FF1 Same problem
                  • CammyTier1
                    CammyTier1 commented
                    Editing a comment
                    Try them all
                    1) 1SUQpsbf8tzWEMH1
                    2) PJQrNkF9cDG9LyrU
                    3) k2QkzQkes74xeM3Z
                    4) 4MMGGypdd2erQRMQ
                    Press CTRL + Enter
                • elvirpa800
                  • Nov 2019
                  • 27
                  • Deutschland
                  Not working
                  Same with US and EU Keyboard. Incorrect Password entered!
                  Thanks anyway
                  Is there any way to remoove Password from my Bios Backup Dump ?
                  • elvirpa800
                    • Nov 2019
                    • 27
                    • Deutschland
                    Hello People
                    Its a
                    W25Q128FVSQ
                    Ok installed Windows on other same Laptop,than put back SSD.
                    Dont need Bios Access.
                    Thanks for all Sugestions.
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • Akhlz001
                      by Akhlz001
                      09-20-2025, 07:15 PM
                    • harounHD
                      Request bios unlock for dell precision 3530
                      by harounHD
                      St 5vss1z2...
                      10-10-2025, 02:24 PM
                    • DavidChunco
                      Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
                      by DavidChunco
                      Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
                      - Receive help from Dell Support (it is out of warranty).
                      - Disconnect machine from AC power and battery overnight.
                      - BIOS recovery process
                      - Connected external display via HDMI
                      - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
                      03-15-2025, 11:00 AM
                    • remizbushka
                      Dell inspirion 5775 bios "Unlock Setup fail"
                      by remizbushka
                      Hi sirs. please help
                      Dell Inspiron 5775 bios locked "Unlock Setup fail"
                      After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                      What I did:
                      I read the bios dump.
                      Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                      03-24-2025, 09:07 AM
