ZBook 15u G6 BIOS CRESCENT-6050A3022501-MB-A01
  • jm801
    Banned
    • Apr 2020
    • 123
    • monterrey
    can you help me does not give image
  • hoaca388
    Badcaps
    • Jan 2022
    • 11209
    • Viet Nam
    Re: ZBook 15u G6 BIOS CRESCENT-6050A3022501-MB-A01
    ZBook 15u G6
    • litsnsirn
      • Dec 2021
      • 29
      Zbook 15u g6 bios chip location
      Hi All,
      Can anyone point me in the direction of the bios chip(s) for a Zbook 15u G6?
      I believe it to be the same board layout as a 840 G6, too. The packages look different than what I'd normally expect, unless I'm looking in the wrong spot.
      TIA
        • 20318
        Re: Zbook 15u g6 bios chip location
        Originally posted by litsnsirn
        Hi All,
        I believe it to be the same board layout as a 840 G6, too. The packages look different than what I’d normally expect, unless I’m looking in the wrong spot.
        TIA
        there`s a schematic boardview ,search for SPI https://www.badcaps.net/forum/showpo...93&postcount=6
        • litsnsirn
          • Dec 2021
          • 29
          Is it a 8-wson on this board? I was poking around and the only Winbond chip I was able to see was hiding under some black sticky plastic under the wireless wan card.
          • hsnckr55
            • Nov 2017
            • türkiye
            hp zbook 15u g6 there is a password in the bios need help
            hello, there is a password in the bios on my hp zbook 15u g6, can you remove this password?
            or can you share 32 and 16 mb bios with this device
            mainboard code crescent-6050a3022501-mb-a01(a1)
            https://dri*******************Mv/view?usp=share_link
              • 20318
              Re: hp zbook 15u g6 there is a password in the bios need help
              You MUST:
              Read BIOS guides, methods, resources and tools
              Try the method at BIOS guides, methods, resources and tools before requesting help
              Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
              Post under a related thread if it exists
              Provide a BIOS/EC dump if possible
              Attach files directly to your post instead of linking to external websites
              • alfanikos
                • Jul 2013
                • 39
                • Greece
                Zbook 15U G6 motherboard 6050A3022501-MB-A01-1 BIOS file Request
                Zbook 15 G6 with motherboard 6050A3022501-MB-A01-1 similar to elitebook 850 G6 and 840G6 has suffered a damage in the BIOS.
                Computer cannot be started and goes into a loop with fan ON keyboard leds ON all OFF and then again same infite loop. (I have a video but i cannot post)
                BIOS is not posting at all
                BIOS Chip MXIC_MX25L25673GZ4I_08G 6x8
                Questions:
                1. Can Someone post the original BIOS file?
                2. Is there a way to extract this BIOS file from the most recent HP update (HP support site)
                3. I will be using the programmer CH341a for programming. Since it is the first time I am doing that, are there an instructions/piece of advice/precautions ?
                4. If an elitebook 850 G6 BIOS is given how will I change BIOS information to indicate that it is a Zbook 15U?
                Thank you in advance
                  • 20318
                  Re: Zbook 15U G6 motherboard 6050A3022501-MB-A01-1 BIOS file Request
                  Questions:
                  First of all please read the rules and post the laptop serial number - https://www.badcaps.net/forum/showthread.php?t=103570 .In that thread there`s a link to the "BIOS guides, methods, resources and tools" thread, there`s some info about programming with the CH341A,and some alternative better software such as NeoProgrammer . You have a socketed bios thats good, but do you have a WSON8 adapter board to solder the chip onto,or have one with a lid,like the socket on your board ?
                  https://www.aliexpress.com/item/32847804960.html
                  https://www.aliexpress.com/item/1005004045901323.html
                  Its very important that you make a good backup of your own bios,even if it is corrupted in some way.It could be repairable. I would not recommend flashing any other bios until you make good backups.
                  • alfanikos
                    • Jul 2013
                    • 39
                    • Greece
                    Questions:
                    Thank you for the swift answer. I will study all links and revert
                    Serial number as and Product Number as mentioned in the photo
                    • rex98
                      • Feb 2023
                      • 1238
                      • Mandaue CEBU, Philippines
                      use this no need DMI data no need rebuild. flash first the 32mb leave the 16mb if it doesn't boot use both 32 and 16.
                      it works in these models HP EliteBook 840 G6 BIOS ZBook 15u G6
                      R70_010300- CRESCENT-6050A3022501-MB-A01
                      note: make sure your ssd with os from that laptop is installed in first boot.
                      it auto recovers DMI in ssd installed.
                      • alfanikos
                        • Jul 2013
                        • 39
                        • Greece
                        Can you please clarify or tell me where do I have to read in order understand when you say flash the 32 and then the 16. What is the difference.
                        I went in detail trough the write up and I have extracted the XXX.bin file for the Hp support site. Will that extracted official bin file not work??
                        What programmer are you advising me to use?
                        • rex98
                          • Feb 2023
                          • 1238
                          what i mean is flash the main 32mb first do not touch your original EC16MB.
                          if it doesn't work use both main and ec.
                          you can use ch341a with neo programmer. do not use AS programmer it's outdated. or use any spi programmer
                          • alfanikos
                            • Jul 2013
                            • 39
                            • Greece
                            Yes it is clear now and thanks alot for the clarifications. May I ask some questions in case the answers are known:
                            1. After having one or two chips flashed and on condition that system has been restored and computer has started (normal operation) will lit be possible to re-update the system the normal way or i have to always keep the given firmware you have given me.
                            2. Say that system is restored with one chip changed (the 32mb) will the second one EC16 will be influenced during a BIOS update?
                            As far as the programmer CH341a i saw that i have to do a voltage modification (voltage reduction) due to a design flaw in the power supply
                            Studying the reverting with results
                            • alfanikos
                              • Jul 2013
                              • 39
                              • Greece
                              Everything has been rectified and the computer came alive again after the very good instructions of SMDflea and REX98
                              I flashed the x32 (Macronix controller) with the universal BIOS
                              Of course I went in detail, through the links for BIOS Guides.
                              Special Thanks to the above mentioned members and to all community for the knowledge put her in this excellent site
                              • alfanikos
                                • Jul 2013
                                • 39
                                • Greece
                                Motherborad Exchanged Zbook 15uG6 vs Elitebook 850G6 (tool required)
                                Very recently a new motherboard form an Elitebook 850 G6 was installed in a Zbook 15u G6.
                                Can someone advice if any link with:
                                1. HP tool to change the particulars (Serial Number, Model Number SKU) of the new motherboard (Elitebook 850 G6 ) to the old one (Zbook 15 G6) existing details of the computer casing
                                2. Instruction to do that..
                                I read something about HP DMI tool, but i need to know which version and procedure.
                                Thanks is advance
                                • alfanikos
                                  • Jul 2013
                                  • 39
                                  • Greece
                                  Zbook 15U G6 import the Serial Number and change the p/N
                                  May I request the assistance of the community.
                                  Mother board has been changed in subject Laptop.
                                  No indicates 840G5
                                  I want to change the P/N, S/N and of course the name of the Laptop.
                                  I have tried DMI tools versions 2.10 up top 2.14-1 as well as the BCU utility
                                  No success
                                  The Manufacturers Programing Mode (MPM is always in lock mode and cannot be altered
                                  Can someone assist bu advising how to alter the data for the existing motherboard by using utilities ?
                                  Do I need to flash the BIOS?
                                  • Focus2005
                                    HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                                    by Focus2005
                                    Hello everyone.
                                    I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                                    05-01-2025, 05:41 AM
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • grimacelord
                                    Latitude E6530 - Trouble Extracting BIOS Image From EXE
                                    by grimacelord
                                    Hi folks,
                                    I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
                                    Service tag number for this model is: "JYDWYW1".
                                    Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
                                    I have tried:
                                    • Simply extracting with 7zip
                                    • PFSExtractor
                                    • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
                                    • Check Temp folder
                                    10-26-2023, 08:15 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • Wahaz
                                    by Wahaz
                                    10-30-2023, 08:42 PM
