820-01700 A2141 DAMAGED T2 ROM IC (dump from other rom?)
  • dam1inc
    • Jan 2017
    • 13
    Is it possible to use T2 ROM dump from another device?
  • smzlwan223
    • Mar 2022
    • 20
    • 中国
    Re: 820-01700 A2141 DAMAGED T2 ROM IC (dump from other rom?)
    You can go into DFU mode, just swipe the phone to restore it, use other roms as well, and have to refresh the T2
    • heatorious
      • Apr 2020
      whats wrong with it post the orig
      • dam1inc
        • Jan 2017
        • 13
        I damaged the chip some how, but it looks like you can use the T2 Rom dump from another device. My A2141 was MDM locked. I pulled the SPI chip off another device, downloaded a dump I found on vinafix.vn, changed the sn, flashed the chip, restored and voila !
        • abajor
          A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
          by abajor
          Like title says A2141 came in with Water Damage, customer desperately wants the data.
          The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
          I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
          That said after cleaning up the...
          12-21-2024, 07:16 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • Mephysis
          DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
          by Mephysis
          Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
          I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
          03-27-2025, 02:34 AM
