ASUS ROG GL703GE EC and BIOS dump needed (DABKNBMB8D0)
  • mitchw
    • 136
    • Slovenia
    Need both BIOS dump and EC dump for the DABKNBMB8D0 REV. D laptop.
    Bit of a history on the board:
    Audio codec ALC295 removed as it was getting hot, no improvement.
    Already tried it with one unverified BIOS and it didn't work. No reaction on power button press. 3.3V LDO present. No shorts. Sometimes it kinda starts, but only partially (5V and 3.3V and 1.05V present, no other rails/VCOREs). Won't charge the battery either - battery charges fine on other board. No activity on charger IC data lines also.
    EC is next suspect, but would also need to find a way to flash it (ITE 8587E). Only have CH341 and TL866II at the moment.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11717
    Re: ASUS ROG GL703GE EC and BIOS dump needed (DABKNBMB8D0)
    This is EC file but need original bios for build new file bios.
    • mitchw
      • 136
      • Slovenia
      Thanks, will try this. What programmer do you recommend for ECs?
      Original BIOS in attachment
      • hoaca388
        Badcaps
        • Jan 2022
        • 11717
        Check support list of RT809H
        https://www.hklrf.com/24download/img/RT809H-List.txt
        • mitchw
          • 136
          • Slovenia
          Thank you. I can borrow a RT809H in a day or two. Any info on how to hook it up to the EC?
          • hoaca388
            Badcaps
            • Jan 2022
            • 11717
            Looks like the connection is via the keyboard cable slot.
            • hoaca388
              Badcaps
              • Jan 2022
              • 11717
              ASUS ROG GL703G bios
              • mitchw
                • 136
                • Slovenia
                Hey, finally got the RT809F that I ordered few months ago. I also got the PEB-1 expansion board for it.
                The RT809F itself works fine, with it I reprogrammed KB9022 on 2 boards so far.
                But the PEB-1 with IT8987 on this board it is giving me nothing but frustration.
                For 4 straight hours I troubleshooted it with no avail. I first soldered the new IT8987 on the ITE Adapter board that plugs into a PEB-1.
                Got the "Chip failed enter into the ISP status, operation terminated." every time I wanted to read it or do anything else with it.
                I then resoldered the chip on the board, and the board actually powers on (kinda), CPU and GPU gets hot, but there is no image and no activity on the USB. Also no battery charging. There is possibility that the EC I put on was pulled from some board that already has some code in it. Or there is some other problem and the EC got flashed from the main BIOS and there is nothing wrong with it.
                I then discovered that there is a debug port near the EC that accepts the 24-pin flat cable. Again, I connected it, set the lines on the RT809F (triple checked them). Did all the right things (connected the ground wire), plugged the board in, etc.
                And I am still getting the darned: "Chip failed enter into the ISP status, operation terminated." in RT809F program.
                Any suggestions why it is failing the detection? I am suspecting the PEB-1 board, but can't prove it.
                The reason I replaced the EC on the first time is that it was getting slightly warm, but there is a chance it was fine, just flashed with some wrong program.
                • eduardo11791
                  • Mar 2013
                  • 7
                  • Venezuela
                  Any luck with the board. I got 5 of those board that I have to work with. Will get the programmer tomorrow. I do have the original BIOS on 2 other functional working motherboards.
                  Funny enough even though the motherboards are the same model and revision, they have 3 different bios chips! That's nuts. Am I looking at the wrong component?
                  Here is a board diagram that I found out https://www.badcaps.net/forum/showth...ht=DABKNBMB8D0
                  The chips that the board has are the following 3:
                  Board model: DABKNBMB8D0 Rev. D
                  Windbond W25Q128JVSQ
                  Gigadevice:25B127DSIG
                  MACRONIX: Can't find the board, Will look it up later.
                  • kostukas1985
                    • 15
                    • lithuania
                    Asus GL703GS GTX1070 8 GB VBIOS DUMP
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • TacticalFahrrad
                      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                      by TacticalFahrrad
                      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                      06-30-2025, 04:09 AM
                    • vinaypundith
                      Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                      by vinaypundith
                      I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                      So, I'm looking for a BIOS dump for this machine - a 16MB one....
                      08-03-2024, 12:32 PM
                    • James Maxwell
                      HP DM1-4000er Bios Dump needed
                      by James Maxwell
                      I badly need bios dump for HP DM1-4000er,
                      Model: HP DM1-4000er
                      Motherboard: DA0NM9MB6D0 REV.D
                      Product: QJ490EA#ACB
                      Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                      10-28-2024, 05:38 PM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
