15-n065sa bios
  • layad
    • Nov 2011
    • 244
    15-n065sa bios
    hi there, have hp laptop 15-n065sa , was completly dead, fixed it( water damage) started to to come on, fan spininig but nothing on screen, after some rail test i doubted the bios chip, downloded a file from hp website, flashed it and laptop started to work but no serial number etc , is it possible to fix the original file rather than flash new one?
    thanks
  • hoaca388
    Badcaps
    • Jan 2022
    • 12268
    Re: 15-n065sa bios
    thanks
    Of course
    • layad
      • Nov 2011
      • 244
      Re: 15-n065sa bios
      Originally posted by hoaca388
      Of course
      thank you , is that the original file i uploaded? as the bios id of the original is 02161.f66 , and the one u uploaded is 02161.f72
      • hoaca388
        Badcaps
        • Jan 2022
        • 12268
        Re: 15-n065sa bios
        The file is searched on the HP homepage by the serial number from your original file. F66 or F72 is just an older or newer version. I added the DMI and windows key information from the old file to the new file.
        • layad
          • Nov 2011
          • 244
          Re: 15-n065sa bios
          thank you , worked
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
          • Forest79
            by Forest79
            07-23-2023, 07:39 AM
          • maanee11
            Help to get Lenovo BIOS bin file for Thinkpad T560
            by maanee11
            Hello Everyone,
            I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
            https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
            In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
            05-15-2022, 11:59 AM
