hp 15s daop5dm8co bios rev c:
  • shabbir.asas
    • Oct 2018
    • 82
    • kuwait
    hp 15s
    daop5dm8c0 rev c :
    plz i need bios its urgent
  • peste
    • Dec 2016
    • 12742
    • ROMANIA
    Re: hp 15s daop5dm8co bios rev c:
    Originally posted by shabbir.asas
    hp 15s
    daop5dm8c0 rev c :
    post the full name and model of the laptop and the original bios
    • shabbir.asas
      • Oct 2018
      • 82
      • kuwait
      hp 15s-fq1018ne
      board no da0p5dmb8c0 rev c:
      • peste
        • Dec 2016
        • 12742
        • ROMANIA
        hp 15s-fq1018ne
        bios extracted from the HP site update
        DMI 480000 - 4810FF
        KEYWIN A9E000 - A9E03F
        • shabbir.asas
          • Oct 2018
          • 82
          • kuwait
          thanks peste its working
          • rsing3d
            • Jul 2021
            • 20
            • usa
            HP 15-dy1071wm
            Hi I need this BIOS for this laptop, the motherboard model is DA0P5DMB8C0 Rev C.
            Thank you
            • hoaca388
              Badcaps
              • Jan 2022
              • 11706
              Re: HP 15-dy1071wm
              Thank you
              Upload your original bios from mainboard. What's brand , model, serial ?
              • rsing3d
                • Jul 2021
                • 20
                • usa
                Re: HP 15-dy1071wm
                I cannot upload the original BIOS, the BIOS chip is dead. Pin 1 is shorted and using a programmer cannot even recognize it. I have a BIOS chip but it is blank.
                The laptop is the following:
                Brand: HP
                Model: 15-dy1071wm
                Serial: 5CD050L05G
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11706
                  Re: HP 15-dy1071wm
                  Brand: HP
                  Model: 15-dy1071wm
                  Serial: 5CD050L05G
                  Because i don't know your bios chip's model, so you must try of files. One by one.
                  • rsing3d
                    • Jul 2021
                    • 20
                    • usa
                    Re: HP 15-dy1071wm
                    The BIOS Chip model is the following: 25B127DSIG
                    I will try them all and see which one works.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11706
                      Re: HP 15-dy1071wm
                      Is this your original chip ? try with 16MB bios.
                        • 20795
                        Re: HP 15-dy1071wm
                        Brand: HP
                        Model: 15-dy1071wm
                        Serial: 5CD050L05G
                        Pin 1 is shorted on the board or off.What model is your programmer
                        • rsing3d
                          • Jul 2021
                          • 20
                          • usa
                          Re: HP 15-dy1071wm
                          Pin 1 is shorted on the motherboard. In diode mode it shoes 0.005V to GND.
                          The programmer is CH1341A.
                          • rsing3d
                            • Jul 2021
                            • 20
                            • usa
                            Re: HP 15-dy1071wm
                            On the original BIOS chip Pin 1 is shorted on the motherboard as well as off the motherboard. In diode mode it shoes 0.005V to GND.
                            • marksik
                              • Jun 2019
                              • 27
                              • Spain
                              Does anyone has bios dump for 15s-fq1013ns
                              Hello. Does anyone has bios dump for 15s-fq1013ns?
                                • 20795
                                Re: Does anyone has bios dump for 15s-fq1013ns
                                Post the motherboard part number , for example DA0P5DMB8C0.
                                • marksik
                                  • Jun 2019
                                  • 27
                                  • Spain
                                  Exactly da0p5dmb8c0
                                    • 20795
                                    Exactly da0p5dmb8c0
                                    Do you have a bios backup you can post. You can get a bios from the hp support page,run the exe and choose copy to a location,it will extract a full bios. You need to look at your backup to find the BID number,you can flash the virgin bios but you`ll lose DMI data,serial number,feature byte etc. The DMI can be copied from your backup with a hex editor .If you can`t do that post your backup.If you havnt got a backup then try all the extracted ones and then use HP Bios config utility and/or wndmifit to add the DMI.
                                    • DynaxSC
                                      by DynaxSC
                                      11-17-2023, 10:56 AM
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • Vesko356
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
