HP EliteBook x360 830 G7 bios password
  • solomost
    • Sep 2021
    • 39
    • agadir
    #141
    Originally posted by minhdigital
    Send to you
    not working bi have black screen caps lock blinking 7 time + fan not spining . what s the probleme
    • hoaca388
      Badcaps
      • Jan 2022
      • 12272
      #142
      Double check to see if you accidentally moved the very small components around the bios chip.
      • solomost
        • Sep 2021
        • 39
        • agadir
        #143
        I checked it, nothing changed. I found out that the BIOS SHIP is damaged. I replaced it with another one and programmed it with the original file. It didn't work either (caps lock hold on) . I think I lost everything.
        Can you repair the original file? thank you for help master
        • eriko45
          • Dec 2023
          • 13
          • Kenya
          #144
          i have hp elitebook x360 830 g7 with no display fan just spins at maximum speed,someone to clean the bios for me.
          SN:5CG04544Y3
          PRODUCT ID:2X8U2PA#ABG
          BOARD NUMBER:6050A3142001-MB-A01(A1)
          THANK YOU IN ADVANCE.
          • eriko45
            • Dec 2023
            • 13
            • Kenya
            #145
            Originally posted by shiyab
            hi try and feedback
            can you please post this bios file i want to use it,am trying to open but it keeps saying invalid file.Thank you
            • shiyab
              • Sep 2023
              • 1592
              • india
              #146
              HI try
              • eriko45
                • Dec 2023
                • 13
                • Kenya
                #147
                HI try
                i tried but it didnt work,the file is unconfigured when run through the MEANALYSER.
                can you please clean this one for me, https://www.badcaps.net/forum/troubl...04#post3703504
                the fan spins at max speed and no display,
                SN:5CG04544Y3
                • teokarafou
                  • Feb 2018
                  • 28
                  • Greece
                  #148
                  HELLO I HAVE BLACK SCREEN AND F5 AND F8 ORANGE LIGHT,HERE IS THE BIOS DUMP,IF SOMEONE CAN HELP WITH A CLEAN AND WORKING BIOS
                  HP ELITEBOOK X360 830 G7
                  SN: 5CG0473033
                  PRODID: 177F8EA#AB7
                  • Blaze Tech
                    Learner
                    • 214
                    • Ghana
                    #149
                    SN: 5CG0473033
                    PRODID: 177F8EA#AB7
                    try
                    • teokarafou
                      • Feb 2018
                      • 28
                      • Greece
                      #150
                      Originally posted by Blaze Tech
                      try
                      DIDNT WORK
                      • jonico2007
                        • May 2022
                        • 30
                        • Philippines
                        #151
                        May I request to unlock bios
                        SN# : 5CG1019MXT
                        ProdID: 1D0E6UT#ABA
                        Build Id : 20WWOLBT601#SABA#DABA
                        Feature byte : 3X476J6S6b7B7H7MR7W7maBapaqauawb8bVbhcAdUdpdqfAfPguhKhkjhkmE.Q2
                          • 21690
                          SN# : 5CG1019MXT
                          ProdID: 1D0E6UT#ABA
                          Patch the 16MB EC_Bios with RCUnlocker - https://www.badcaps.net/forum/troubl...23#post1622423
                          • jonico2007
                            • May 2022
                            • 30
                            • Philippines
                            #153
                            I already tried this. I also tried to factory reset the bios settings. It shows no bios password but when I tried to install the operating system, can't skip the sign in option with microsoft aggreement. It seems that need to sign in on previous service.
                            • koshin
                              • 8
                              • Poland
                              #154
                              SN# : 5CG1019MXT
                              ProdID: 1D0E6UT#ABA
                              Try this.
                              • Scottyvr1
                                • Feb 2020
                                • 4
                                #155
                                I have a Elitebook 830 G7 that has the bios locked, I removed the motherboard and the Bios chip (Winbond 25Q128JVPQ) I soldered the chip on my CH341A and read the data, I followed a youtube tutorial to remove the password by replacing lines of code with FF to remove the password etc, I then reinstalled the chip but now get HP Endpoint Security Controller Problem as well as the bios password is still there. I have obviously done some thing wrong.
                                I have now removed the chip again read the data and dropped it into RC Unlocker which has generated an unlocked Bin file. Could somebody please take a look at this file and see if they can see why I am getting the HP Endpoint error.
                                Thanks in advance
                                • peste
                                  peste commented
                                  Editing a comment
                                  post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                              • Scottyvr1
                                • Feb 2020
                                • 4
                                #156
                                file attached
                                • Scottyvr1
                                  • Feb 2020
                                  • 4
                                  #157
                                  SN#5CG1033RNM
                                  CAMELLIA-6050A3136201-MB-A01(A1)
                                  PRODUCT ID 113X7ET#ABU
                                  I have tried running the script in tiny hexer to fix the endpoint error but it doesn't work. I get line 3, error 65: Cannot open file"C:\ENDPOINT\endpoint.bin"
                                  • peste
                                    • Dec 2016
                                    • 13436
                                    • ROMANIA
                                    #158
                                    Originally posted by Scottyvr1
                                    SN#5CG1033RNM
                                    try this..
                                    https://www.badcaps.net/forum/troubl...er#post3310855
                                    • Scottyvr1
                                      • Feb 2020
                                      • 4
                                      #159
                                      Originally posted by peste
                                      Thanks very much for your help, I will give it a try when I take out the main board again.
