HP EliteBook x360 830 G7 bios password
  • koshin
    replied
    Originally posted by jonico2007
    May I request to unlock bios
    SN# : 5CG1019MXT
    ProdID: 1D0E6UT#ABA
    Build Id : 20WWOLBT601#SABA#DABA
    Feature byte : 3X476J6S6b7B7H7MR7W7maBapaqauawb8bVbhcAdUdpdqfAfPguhKhkjhkmE.Q2
    Try this.
  • jonico2007
    replied
    Originally posted by SMDFlea
    Patch the 16MB EC_Bios with RCUnlocker - https://www.badcaps.net/forum/troubl...23#post1622423
    I already tried this. I also tried to factory reset the bios settings. It shows no bios password but when I tried to install the operating system, can't skip the sign in option with microsoft aggreement. It seems that need to sign in on previous service.
    replied
    SN# : 5CG1019MXT
    ProdID: 1D0E6UT#ABA
  • jonico2007
    replied
    SN# : 5CG1019MXT
    ProdID: 1D0E6UT#ABA
  • teokarafou
    replied
    Originally posted by Blaze Tech
    try
    DIDNT WORK
  • Blaze Tech
    replied
    Originally posted by teokarafou
    HELLO I HAVE BLACK SCREEN AND F5 AND F8 ORANGE LIGHT,HERE IS THE BIOS DUMP,IF SOMEONE CAN HELP WITH A CLEAN AND WORKING BIOS
    HP ELITEBOOK X360 830 G7
    SN: 5CG0473033
    PRODID: 177F8EA#AB7
    BOARD NUMBER:6050A3142001-MB-A01(A1)
    try
  • teokarafou
    replied
    SN: 5CG0473033
    PRODID: 177F8EA#AB7
  • eriko45
    replied
    Originally posted by shiyab
    HI try
    i tried but it didnt work,the file is unconfigured when run through the MEANALYSER.
    can you please clean this one for me, https://www.badcaps.net/forum/troubl...04#post3703504
    the fan spins at max speed and no display,
    SN:5CG04544Y3
    PRODUCT ID:2X8U2PA#ABG
    THANK YOU IN ADVANCE
  • shiyab
    replied
    Originally posted by eriko45
    can you please post this bios file i want to use it,am trying to open but it keeps saying invalid file.Thank you
    HI try
  • eriko45
    replied
    hi try and feedback
  • eriko45
    replied
    i have hp elitebook x360 830 g7 with no display fan just spins at maximum speed,someone to clean the bios for me.
    SN:5CG04544Y3
    THANK YOU IN ADVANCE.
  • solomost
    replied
    Originally posted by hoaca388
    Double check to see if you accidentally moved the very small components around the bios chip.
    I checked it, nothing changed. I found out that the BIOS SHIP is damaged. I replaced it with another one and programmed it with the original file. It didn't work either (caps lock hold on) . I think I lost everything.
    Can you repair the original file? thank you for help master
  • hoaca388
    replied
    Originally posted by solomost
    not working bi have black screen caps lock blinking 7 time + fan not spining . what s the probleme
  • solomost
    replied
    Originally posted by minhdigital
    Send to you
  • minhdigital
    replied
    HI team
    some one help me to removing password bios for elitbook 830 g7
    SN : 5CG0487DVC
    Motherboard: AVA94V-0
    E253117 AVARY
    THANK YOU
    Send to you
  • solomost
    replied
    HI team
    SN : 5CG0487DVC
    E253117 AVARY
    THANK YOU
  • Carlito Jr. Tiopan
    replied
    30....restart....29. 29...restart...28
    Thank you sir i input all the data and its now okey
  • hoaca388
    replied
    Originally posted by Carlito Jr. Tiopan
    done flashing eveytime i boot the device its said "system is booting in manufacturing ..... Program mode : 30" that number keeps descending every boot
    replied
    Endpoint security controller problem.
  • hoaca388
    replied
    hello good sir the unit boots now but I received an error hp endpoint security controller problem
