HP Pavilion Gaming DA0G3hmb8d0 rev d G3HA
  • akbari_808
    • Jan 2019
    • 20
    • United Kingdom
    Re: HP Pavilion Gaming DA0G3hmb8d0 rev d G3HA
    thank you hoaca388 for the file you sent me, unfortunately the laptop is still dead when i put this bios file. any ideas?
    • hoaca388
      Badcaps
      • Jan 2022
      • 11798
      Is 5CD019FPRD your serial number? The file I posted is a clean bios from HP, if the device doesn't work then you have a hardware failure.
      • Rebeli
        • Jun 2014
        • 3
        • Finland
        this bios worked thank you very much
        Originally posted by hoaca388
        HP Pavilion Gaming - 15-ec0006na
        • crocodilu112
          • Feb 2013
          • 3
          • Romania
          Please I need bios 25LQ128 for this HP 15-ec0002nq model DA0G3hmb8d0 rev d G3HA S/N#5CDC94110Q7 .Thanks!
          • peste
            • Dec 2016
            • 12859
            • ROMANIA
            your bios is at post #12..don't forget to make a copy of the original bios before writing the chip..always when you make a bios request post the original bios of the laptop, even if it is corrupted..
            • crocodilu112
              • Feb 2013
              • 3
              • Romania
              #26
              Thanks!
              • tktrom
                • Jul 2022
                • 79
                • Bolivia
                #27
                good afternoon, I have an HP Pavilion Gaming - 15-ec0002la model
                DA0G3hmb8d0 rev d G3HA, that when I put the bios from the hp web page, it turns on the machine and starts flashing the bios and when it finishes and restarts there is no video.
                Could someone help me please, I publish the original bios.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #28
                  There'll be a few restarts so be patient and wait for the power sequence to finish, and hopefully machine to boot successfully at the end.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                  • Tobiichi33
                    • Nov 2019
                    • 10
                    • indonesia
                    #29
                    I use the bios above but it happens clearing pending image
                    Board : DA0G3HMB8D0 Rev D G3HA
                    AMd ryzen 5 3550
                      • 20990
                      AMd ryzen 5 3550
                      Serial number,backup etc etc -> https://www.badcaps.net/forum/showthread.php?t=103570
                      • Tobiichi33
                        • Nov 2019
                        • 10
                        • indonesia
                        #31
                        S/N : 5CD9515Z0D
                        I do not have backup, because I would be careless not to backup
                        Thank you for your help
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11798
                          #32
                          S/N : 5CD9515Z0D
                          HP Pavilion Gaming - 15-ec0001ax
                          • Tobiichi33
                            • Nov 2019
                            • 10
                            • indonesia
                            #33
                            Thank you, I will try it soon, I will post the results
                            • Tobiichi33
                              • Nov 2019
                              • 10
                              • indonesia
                              #34
                              the result remains the same
                              after the screen turns off it doesn't turn back on and the fan spins fast sometimes slows down
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11798
                                #35
                                You should look for hardware solutions because the file I gave is the original file from HP.
                                • Tobiichi33
                                  • Nov 2019
                                  • 10
                                  • indonesia
                                  #36
                                  Thanks for advice, i hope
                                  • joeny8383
                                    • Sep 2019
                                    • indonesian
                                    #37
                                    Originally posted by lapfix
                                    Fix it ...
                                    My solution :i download old bios version from HP site , dumped and the lap start a serial of update between bios and EC 4 or 5 times ...than all is OK .
                                    hallo lapfix, can you send me your fix bios in this chase, my problem its same. i try download old bios in the hp site but still same, laptop display and report "pending clear bios etc" then restart no display again
                                    • peste
                                      • Dec 2016
                                      • 12859
                                      • ROMANIA
                                      #38
                                      read these rules first..
                                      • dachamcse
                                        • Mar 2018
                                        • 33
                                        • Serbia
                                        #39
                                        Do you have a bios for DA0G3hmb8d0 rev d G3HD ?
                                      • Rudisuha
                                        • Aug 2024
                                        • 8
                                        • Indonesia
                                        #40
                                        I also have the same problem, please help ,hp pavilioon gaming 15-ec0001AX DA0G3HMB8D0 REV D, SN : 5CD9515ZTV. I also attach the original bios file
                                          HP Pavilion Gaming Pavilion Gaming - 15-ec0515na Notebook 15 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Gaming Pavilion Gaming - 15-ec0515na Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Gaming - 15-ec0515na boardview and Pavilion Gaming - 15-ec0515na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 12:20 PM
                                          HP Pavilion Gaming Pavilion Gaming - 15-ec0020na Notebook 15 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Gaming Pavilion Gaming - 15-ec0020na Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Gaming - 15-ec0020na boardview and Pavilion Gaming - 15-ec0020na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 12:18 PM
                                          HP Pavilion Pavilion Gaming - 17-cd0024na Notebook Gaming Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Gaming - 17-cd0024na Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Gaming - 17-cd0024na boardview and Pavilion Gaming - 17-cd0024na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 09:23 AM
                                          HP Pavilion Gaming 690-0045ng Pavilion Gaming i7-9700F Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Gaming 690-0045ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Gaming 690-0045ng boardview and Pavilion Gaming 690-0045ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:30 PM
                                          HP Pavilion Gaming 790-0036no Pavilion Gaming i5-9400F Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Gaming 790-0036no can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Gaming 790-0036no boardview and Pavilion Gaming 790-0036no schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
