Acer NITRO 5 AN515-57 need a clean bios
  • luciuslr
    • Jun 2015
    • BRasil
    #181
    Originally posted by SMDFlea
    Have you tried cleaning the ME firmware ? https://www.badcaps.net/forum/troubl...22#post1622422
    I tried to follow the steps to do Clear ME, but when I use FIT, I can't continue.
    • luciuslr
      • Jun 2015
      • BRasil
      #182
      Originally posted by luciuslr
      Hi, can help?
      acer nitro 5 AN517-54-7204
      SNID 236000221935
      S/N - NHQEFAL002236000DD9Z00
      change pch and it does not recognize NVMe​
      Anyone?
        • 21679
        Anyone?
        bios.
        • azemar
          • Nov 2022
          • 46
          • France
          #184
          Hello I'm stuck on the acer logo after changing the chipset and EC SIO. no nvme detection and uefi usb boot blocked .
          Here is the information and my dump:
          ACER AN515-57-528U
          s/n:NHQELEF0052120B93E7000
          SNID:21204742270
          GH51G LA-L181P
          Rev:1C
          2021-07-29
          Thank you
            • 21679
            Have you tried cleaning the ME firmware, and do you have an EC programmer or did you buy the chip already programmed
            • luciuslr
              • Jun 2015
              • BRasil
              #186
              bios.
              It turned on, the keyboard LEDs turned on, turned it off and on twice but it doesn't generate an image.
              • azemar
                • Nov 2022
                • 46
                • France
                #187
                Hello, I bought the programmed part. And no, I don't have an EC programmer.
                • azemar
                  • Nov 2022
                  • 46
                  • France
                  #188
                  As-tu essayé de nettoyer le firmware du ME, et as-tu un programmateur EC ou as-tu acheté la puce déjà programmée
                  I succeeded in making a clean ME, I found but disk nvme in the bios and I can boot on a key usb but there is a problem with the uefi. I do not see but disk when I am in the installation of windows. can you help me?
                • azemar
                  • Nov 2022
                  • 46
                  • France
                  #189
                  hank you very much, it worked. I have one last request: I bought an EC that is already programmed, and I wanted to know if it is possible to modify the serial number/SNID and model directly with software. Thank you."
                    • 21679
                    The serial number should be in your bios but it isn`t, the windows key is there though. If you know how to use a hex editor copy the DMI from one of the other bios in the thread and edit your serial number into it, the offsets are 668000 - 669FFF.
                    Alternatively try the attached software, i don`t know if it will work or not, never used it myself.
                    • azemar
                      • Nov 2022
                      • 46
                      • France
                      #191
                      Thanks I will try
                      • azemar
                        • Nov 2022
                        • 46
                        • France
                        #192
                        I just made the modification, but I still don't have the correct serial number. Can someone provide it for me? I also attached my file with the modified DIM and the original one.
                        Thank
                        INFO: ACER AN515-57-528U
                        SNID:21204742270
                        GH51G LA-L181P​
                        • NICOCARVAL
                          • Aug 2022
                          • 12
                          • Colombia
                          #193
                          HOLA a todos, tengo un acer an515-57-583j cambie PCH pero no me reconoce usb ni NVME, necesito de su ayuda para que pueda detectar y poder instalar windows
                          ACER NITRO 5
                          AN515-57-583J
                          S/N: NHQEKAL00D21003D6A7000
                          SNID:21001570670
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12269
                            #194
                            ACER NITRO 5
                            AN515-57-583J
                            SNID:21001570670
                            English , please !
                            • NICOCARVAL
                              • Aug 2022
                              • 12
                              • Colombia
                              #195
                              Hey, can you help me repair this corrupted BIOS? It won't turn on.
                              ACER NITRO 5
                              AN515-57-583J
                              S/N:NHQEKAL00D21003D6A7000
                              SNID:21001570670
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12269
                                #196
                                ACER NITRO 5
                                AN515-57-583J
                                SNID:21001570670
                                Back to # 75
                                • NICOCARVAL
                                  • Aug 2022
                                  • 12
                                  • Colombia
                                  #197
                                  Hi, thanks for answering.
                                  I tried the first one, it turns on the keyboard but there's no image, and the other two files with no results ​. What could I do?
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12269
                                    #198
                                    Find hardware problem.
                                    • NICOCARVAL
                                      • Aug 2022
                                      • 12
                                      • Colombia
                                      #199
                                      Sorry to bother you, friend. Could you fix the BIOS if it turns back on? I'd appreciate it.
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12269
                                        #200
                                        # 75
