Dell Latitude 7400 EDC40 LA-G871P
  • Bios White
    Learn
    • Dec 2024
    • 69
    • East Laos
    #241
    Originally posted by hoaca388
    Why don't you give up and focus on hardware problems.
    The device has a hardware error related to audio, thank you everyone.
    • LBTT1121
      • Nov 2024
      • 518
      • Việt Nam
      #242
      Originally posted by mateusassuncao
      here is the ut5 dump
      try and feedback
      • mateusassuncao
        • Nov 2024
        • 29
        • Brasil
        #243
        Guys, (laughs) here in Brazil it's already 01:00AM, can anyone help me!?
        • peste
          • Dec 2016
          • 12787
          • ROMANIA
          #244
          try..
          • mateusassuncao
            • Nov 2024
            • 29
            • Brasil
            #245
            Originally posted by peste
            try..
            it worked fine
            tank you veryyy much!
            • docW4rte
              • Feb 2025
              • 9
              • Paraguay
              #246
              Re: Dell Latitude 7400 EDC40 LA-G871P
              Service Tag: 37ZK5Y2
              Good day everyone, could you help me with this BIN? The unit makes one fan revolution and then dies. It displays main voltages but no video at all.​
              • lapfix
                • Mar 2020
                • 2720
                • my workshop
                #247
                Yor serviceTag is different did you flash another bios!!
                AT the sticker is Vpro indicated !!
                Latitude 7400
                Version
                1.39.0.
                Try and Give Feedback​
                • docW4rte
                  • Feb 2025
                  • 9
                  • Paraguay
                  #248
                  Latitude 7400
                  Version
                  1.39.0.
                  I understand, and thank you for the clarification. It's possible that the BIN is no longer the original one, as I received this notebook from a client who had already taken it to another repair service before. However, the Service Tag is authentic and matches the one on the case.
                  After replacing a shorted component in a 1V power rail, I encountered this startup issue. I've tested the file with version 1.39 you shared, but I'm still facing the same problem.
                  Do you think this could be solved with a clean ME?
                  • m4tito
                    • Nov 2024
                    • 8
                    • Wielka Brytania
                    #249
                    Dell is picky and you'll probably need to flash the EC as well. If the EC has a different version than the BIOS, the laptop may sometimes fail to boot.
                    • docW4rte
                      • Feb 2025
                      • 9
                      • Paraguay
                      #250
                      Thank you for the advice. That makes sense—I’ll look into the possibility of flashing the EC as well, although I don’t have prior experience reading the EC on this MEC model. I hadn’t considered that a version mismatch could be the cause. I’ll give it a try. Thanks again for your help.
                      • mmalagelada
                        • Apr 2017
                        • 4
                        • SPAIN
                        #251
                        Someone can point me to the propper chip to read?
                        I can see:
                        - UC6 25Q128JVSQ
                        - UT5 25Q80CSIG
                        - UT2 25Q80DVS1G
                        First one is a 16Mbytes flash SPI, and I can see people here having a 32Mb SPI for the Latitude 7400 LA-G871P
                        If I read UC6 and try to apply REX98 8FC8 patcher, I receive the error :
                        wa nakit-an ang intel signature
                        Pinduta bisan unsang key para ma exit...​
                        I've read using a clip and also desoldering the chip and reading directly connected to the CH341 Black, and the file is always the same.
                        Thanks.
                        • LBTT1121
                          • Nov 2024
                          • 518
                          • Việt Nam
                          #252
                          I can see:
                          - UC6 25Q128JVSQ
                          - UT5 25Q80CSIG
                          - UT2 25Q80DVS1G
                          Thanks.
                          pass on UT5
                            SMDFlea commented
                            Editing a comment
                            Its UC5 ??
                        • mmalagelada
                          • Apr 2017
                          • 4
                          • SPAIN
                          #253
                          I just found a related post in BadCaps. As I see in the photo, it is in the underside ob the PCB.
Name:	LA-G871P UC5 Location.jpg
ID:	3647988 Click image for larger version
ID:	3647989 Click image for larger version
                          • Pasco97233
                            • Jun 2025
                            • Bordeaux
                            #254
                            Hello
                            Who can help me remove the BIOS password?
                            My service tag is: 4XLGYY2
                            Thank you for your help.​
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11727
                              #255
                              Originally posted by Pasco97233
                              Hello
                              File's corrupted.
                              • rioda91
                                • Mar 2022
                                • 11
                                • italia
                                #256
                                hi everyone, can someone help me with this bios of a Dell E5540? it have bios password... thank you very much!
                                  • 20855
                                  Off topic, this thread is for the Latitude 7400 .Find a E5540 topic to post your request in, and include the required service tag. Read the rules - https://www.badcaps.net/forum/troubl...before-posting
                                  • mmalagelada
                                    • Apr 2017
                                    • 4
                                    • SPAIN
                                    #258
                                    Finally got time to do it. SUCCESS!
                                    1: Protect the PCB with aluminium tape. I had no availability for kapton. Nobody wants nearby capacitors flying away.
                                    2: hot blower at 360ºCelsus.
                                    3: Preheat the zone.
                                    4: Attack the SPI Chip that in my case it ws a 25Q64JVIQ in WSON8 Capsule. 30 seconds was enough.
                                    5: Clean the chip and attach the WSON to DIL adapter. Read with the CH347 Black edition reader. Software used: NeoProgrammer V2.2.0.10
                                    6: save the file (8Mb for the 25Q64JV)
                                    7: execute the Badcaps 8fc8 patcher.
                                    8: Flash the patched file to the chip
                                    9: Read and compare to make sure the write was successful.
                                    10: Cure the PCB with the solder, flux, and wick. Drop some solder paste, I used 170ºC fusion point tin-lead paste.
                                    11: Preheat, heat, solder..
                                    12: Clean
                                    13: reassemble and Start the computer
                                    14: Wait 2 to 3 minutes. it will start in Factory Mode.
                                    15: Write the service tag when prompted.
                                    16: Once restarted press Alt+F to exit factory mode.
                                    Password was removed. Donation was made.
                                      DELL Latitude 7400 Notebook 7000 Specification for Upgrade or Repair
                                      This specification for the DELL Latitude 7400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7400...
                                      09-06-2024, 08:40 PM
                                      DELL Latitude 7400 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                                      This specification for the DELL Latitude 7400 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                      09-06-2024, 12:36 PM
