Dell Latitude 7400 EDC40 LA-G871P
  • hichamhb
    • Jun 2019
    • 94
    • morocco
    #161
    Originally posted by hoaca388
    Latitude 7400
    Service Tag: 73HP9Y2
    thank you so much . it's working
    • babayan75
      • Nov 2016
      • 3
      • Ukraine
      #162
      Hi, can anyone help me remove password from this Dump Thank You !
      SERVICE TAG : JJCTZY2
      system number : JJCTZY2 - 8FC8
      • shiyab
        • Sep 2023
        • 1613
        • india
        #163
        HI try unlock
        • babayan75
          • Nov 2016
          • 3
          • Ukraine
          #164
          Originally posted by shiyab
          HI try unlock
          Thank You !
          • hamid_seta
            • Mar 2015
            • 24
            Hi
            Dell Latitude 7400 S/N 9J9JL33 need bios password removal.
            File size is 16MB
            check the attached locked Bios.
            Thansk in advance
            • qayyum786
              • Aug 2018
              • 1959
              • INDIA
              #166
              Originally posted by hamid_seta
              Hi
              File size is 16MB
              Thansk in advance
              Post another bios chip backup 32MB
              • Raziel19935
                • Aug 2019
                • 16
                • República Dominicana
                #167
                HI try unlock
                hello, unlock this bios please
                servicetag: 23YZK33
                LATITUDE 7400
                i really appreciated
                • hamid_seta
                  • Mar 2015
                  • 24
                  there is not any bios 32MB, I made a backup and its 16MB only
                  • hamid_seta
                    • Mar 2015
                    • 24
                    I made the backup from these 3 chip, two of those are 1MB and the 3th one is only16MB - I made 2 times but I am sure it is 16MB
                    Check the attached image
                    • qayyum786
                      • Aug 2018
                      • 1959
                      • INDIA
                      #170
                      servicetag: 23YZK33
                      LATITUDE 7400
                      Try
                      • qayyum786
                        • Aug 2018
                        • 1959
                        • INDIA
                        #171
                        Click image for larger version  Name:	cd95.jpg Views:	0 Size:	708.1 KB ID:	3502436
                        Maybe Raziel19935 will help you to locate 32MB chip if you are on same platform​
                        • hamid_seta
                          • Mar 2015
                          • 24
                          servicetag: 23YZK33
                          LATITUDE 7400
                          Hi
                          would it be possible to send me a picture and locate the bios chipset please .
                          • Raziel19935
                            • Aug 2019
                            • 16
                            #173
                            Hi
                            here UC5 big one
                            • hamid_seta
                              • Mar 2015
                              • 24
                              here UC5 big one
                              Thank you for your response.
                              This motherboard indeed contains four EEPROM chips with the following specifications: two 1MB chips, one 16MB chip, and one 8MB chip. The 16MB EEPROM(UC5), which you mentioned is located on the back of the board, is positioned alongside the chipset.
                              UT6 = 1MB
                              UT2 = 1MB
                              UC6 = 16MB
                              UC5 = 8MB
                              There is not any EEPROM with 32MB capacity !!!
                              it make me confuse !
                              Mainboard Model number : EDC40 LA-G871P
                              anyone any idea ?
                                • 21945
                                UT6 = 1MB
                                UT2 = 1MB
                                UC6 = 16MB
                                UC5 = 8MB
                                it make me confuse !​
                                Your laptop configuration is Non vPro ,so it doesn`t have a 32MB chip. You have 8MB and 16MB .
                                • hamid_seta
                                  • Mar 2015
                                  • 24
                                  Thanks for your information
                                  is there any solution for this type of motherboard
                                  • qayyum786
                                    • Aug 2018
                                    • 1959
                                    • INDIA
                                    #177
                                    Read verify and post UC6 = 16MB UC5 = 8MB
                                    • hamid_seta
                                      • Mar 2015
                                      • 24
                                      *** for those who are stuck on the same device with same chipsets ***
                                      I removed UC5 (8Mb) chip and replace it with 32Mb then I removed the UC6 (16Mb) Chip complately and left the chipset area empty then program the 32Mb chip with bios dump file and BINGO !!! its worked fine
                                      A Bios Program was split into two chipsets But I make it in one chip
                                      Thanks all
                                      • zsi3ug4z
                                        • Aug 2022
                                        • 57
                                        • việt nam
                                        #179
                                        I have a repaired laptop, so i dont have original bios file. This bios dump have a problem with many hidden items.Pls help me unlock this. Thanks!
                                        ST:CGQWF13
                                        • zsi3ug4z
                                          • Aug 2022
                                          • 57
                                          • việt nam
                                          #180
                                          ST:CGQWF13
                                          sorry wrong file attached
                                            DELL Latitude 7400 Notebook 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7400...
                                            09-06-2024, 08:40 PM
                                            09-06-2024, 12:36 PM
                                            DELL Latitude 7400 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7400 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
