Re: Hp elitebook 840 g6 locked bios
since you didn't upload the 16mb try this. ON FIRST BOOT RESET SECURITY SETTINGS IN BIOS. THEN PUT THE DMI MANUALLY VIA MPM TOOL.ALL YOUR DMI ARE IN THE BOARD STICKERS.
Product Name : HP EliteBook 840 G6
System Board CT Number: PHWHN00WBD3I1V
SERIAL :5CG9497JF1
BUILD ID :19WWCFBT601#SABF#DABF7
FeatureByte : 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn
give feedback
HP Elitebook 840 G6 bios password
use RC unlocke, search it in the search optionLeave a comment:
hi badcaps team
need remove Password for this bios
Here bios attachedAttached FilesLeave a comment:
Re: HP Elitebook 840 G6 bios password
i searched the dmi data in unlocked bios then trasfer my dmi to the unlocked ones and now it works.
HERE'S THE GUIDE HOPE YOU ALL UNDERSTAND.
USE MY BIOS DUMP IN THE ATTACCHMENT HP 840 G6 SWAT UNLOCKED.
SERIAL NUMBER BLOCK ADDRESS : 00749807 , 00757cab , 00794cfd , 007a6dc5 , 007a6e89 , 018fd9ee , --> edit and put your serial number in that 6 address
SYSTEM BOARD CT BLOCK ADDRESS: 007aaf51 and 018fdaf4 -->edit and put your CT number in that 2 address
MAC ADDRESS: 01900040 -->edit and put your MAC ADRESS in that address ITS ENCODED IN UNICODE STRING SO DONT DELETE THE DOT.
BUILD ID: 018fe754 -->edit and put your BUILD ID in that address
THEN IN FIRST BOOT GOTO BIOS PRESS F10 RESET SECURITY TO DEFAULTS. THEN USE MPM TOOL IN WINDOWS PUT ALL THE DMI FROM YOUR BOARD are LOCATED in THE STICKERS..
MAKE SURE YOU FORMAT THE OLD SSD WITH LOCK BEFORE BOOTING TO WINDOWS. I USED HEX EDITOR NEO CRACK.Attached FilesLeave a comment:
unlock this please it has swatlock/computrace. TIA
SN: 5CG9311TZC
i managed to unlock the bios password by myself in neo hex editor the 16mb chip. but my problem now is the absolute lock. my patch doesn't work from files i compared here.Last edited by rex98; 08-15-2023, 03:03 AM.Leave a comment:
Good day everyone..Can someone remove password and computerace on my hp elitebook 840 g6.. thanks your help will much apreciated..Attached FilesLeave a comment:
Re: hp elitebook 840 g6 please help bios unlock
anyone can help me Hp elitebook 840 g6 to unlock
thanks
HP ELITEBOOK 840 G6 SWAT LOCKED.rarLeave a comment:
try and feebackAttached FilesLeave a comment:
Hi I need this 840 g6 unlocked pleaseLeave a comment:
i try the 2 32mb files but the problem is m2 is not detected , even if i install the driver for m2 i checknin system info in bios m2 not detected,Leave a comment:
Thanx sir i really appreciatte yoour help
Ii alreaddy autto donate in paypal evry monthAttached FilesLeave a comment:
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by BlackVisorRedmiBook Pro 1542022 6800H
SKU: TM2113-39463
Model Number: RMA2204-AB
CMIIT ID: 2022AP1835
SN: 39463/22WD01355
BIOS version: RMARB5B0P1010 20230628
1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...-
01-14-2024, 06:35 AM -
- Loading...
