HP Elitebook 840 G6 bios password
    commented on 's reply
    Close MPM with HP Bios Config Utility ,BCU
  • AE Soft
    replied
    Originally posted by danito
    try
    working, but have error System is Booting in manufacturing program mode 34
  • danito
    replied
    Originally posted by AE Soft
    HP 840 G6 need to clear bios password
    here i have attached my 32MB old bios locked file
    pls help me
    MODEL : HP 840 G6
    S.No: 5CG0148ZFB
    try
  • AE Soft
    replied
    pls help me
    MODEL : HP 840 G6
    S.No: 5CG0148ZFB
  • Lukosiukas
    replied
    try
    Works perfectly.
  • danito
    replied
    Originally posted by Lukosiukas
    HP Elitebook 840 g6
    SN 5CG9456XY7
    Bios locked, i need password removed. Many thanks in advance.
    try
  • Lukosiukas
    replied
    HP Elitebook 840 g6
    SN 5CG9456XY7
    Thread merged.
  • Won Dee
    replied
    I need assistance unlocking the HP Elitebook 840 G6's SWAT lock.
    SN# 5CG0260571
    Thank You
    Post the laptop serial number....
  • loughzal
    replied
    Originally posted by SMDFlea
    Read the rules,post the serial number.
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    hi frind ok.
    modèle : hp elitebook 840 G6
    motherboard code : CRESCENT - 6050A3022501 -MB-A01(A1)
    thinks
  • peste
    merged post...
  • azad007
    replied
    Someone may need this ..tested ok
    replied
    Originally posted by loughzal
    Any help please FOR UNLOCKIN..thank you
    You MUST:
  • loughzal
    replied
  • Blaze Tech
    replied
    Originally posted by kamkooltech
    Hello, I just want to know, is the password save and set on 16mb chip or 32mb??
    Its on the 16mb chip
  • kamkooltech
    replied
    Originally posted by Vesko356
    Re: HP Elitebook 840 G6 bios password
    Most probably you didn't program the chip correctly, or didn't solder it properly.
    Program 16MB chip only, or both if doesn't work. Use verification, be careful.
  • hoaca388
    replied
    Originally posted by serginio
    Hello! Can you help me to unlock bios?
    MODEL : HP 840 G6
    SN 5CG0113Q4B​
    HP EliteBook 840 G6
    CTNumber_6GPRE15WYD5R3A
    Serial_5CG0113Q4B
    Product_4WG26AV
    Feature byte_3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUbhcAdUdpdqfAfPhKhkjhk8.yM
    Build Id_19WWCFBT601#SBCM#DBCM
  • rex98
    replied
    MODEL : HP 840 G6
    SN 5CG0113Q4B
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU. you can permanently disable Absolute lock in BCU.
    here's your DMI:
    Serial Number: 5CG0113Q4B
    Product #/SKU: 4WG26AV
    CT Number: PHWHN00WBDH6OL
    Description: HP EliteBook 840 G6
    BuildID: 19WWCFBT601#SBCM#DBCM
    Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUbhcAdUdpdqfAfPhKhkjhk8.yM
    MAC Address : 38:22:E2:C9:02:92​
  • serginio
    replied
    MODEL : HP 840 G6
    SN 5CG0113Q4B​
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • traxformania
    TONGFANG "GM7TG7P" Bios Password Problem?
    by traxformania
    I tried :
    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
    11-15-2023, 07:32 AM
  • tlindi
    Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
    by tlindi
    Sublect line continuation: ... Jaguar IDS PC aka Panasonic
    Ack
    Ack
    01-30-2025, 04:26 AM
  • Nopslide
    by Nopslide
    04-01-2024, 04:27 PM
  • BlackVisor
    How to Decode BIOS password for RedmiBook Pro15 2022 6800H
    by BlackVisor
    RedmiBook Pro 1542022 6800H
    SKU: TM2113-39463
    Model Number: RMA2204-AB
    CMIIT ID: 2022AP1835
    SN: 39463/22WD01355
    BIOS version: RMARB5B0P1010 20230628
    1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
    2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
    3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
    01-14-2024, 06:35 AM
