Dell Latitude 5520 Bios Password unlock
Re: Dell Latitude 5520 Bios Password unlock
Try this and give feedback.Attached FilesComment
TryAttached FilesComment
try and reportAttached FilesComment
I checked procedure, identical bins reached. Verify chip again, check pad solder, missing or moved components, clean and re-tin pads. I am not sure what is the form factor of chip, probably wson 8x6. Clean middle pad, sometimes it gets too much solder and sort of wobbles when using hot air.Comment
UnlockedAttached Files↵
https://www.badcaps.net/donateComment
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by Jeff'sTechHello everyone.
I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make... -
by YOUCEF4787Hello everyone,
I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
Initial Problem:
The laptop was completely dead, no signs of life, no power LED.
Action Taken:
I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
Current Situation & The Main Issue:
The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly.... -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
- Loading...
