Dell Latitude 5520 Bios Password unlock
Attached FilesComment
tryAttached FilesComment
Please help me remove Dell Latitude 5520 bios admin password
Service Tag: CNZFQL3-8FC8
Thank you very much!Comment
Every donation made will go towards server fees and maintenance costs.Comment
How can I do this? The PC is currently locked with a BIOS administrator password, and the Windows password is also forgotten. I want to recover or remove the BIOS password, but I don’t have any external tools or hardware. The laptop is a Dell Latitude 5520Comment
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
Hi, ya i have a dell 5520 and same bios admin lock. im not sure why people are saying express service # but when i go in and try to get into the bios it gives me this code(btw I have already tried bios-pw.org and it does not work.
28S31B3-8FC8
I do notice you usually send a ".bin" file back? do I run that or?? cuz it wont let me update the bios? sorry, I am an IT guy 25+ years but this has been a bit disturbing for me as usually i can "defeat" this stuff. Thanks!! and cudo's for this website/blog/forum
DaNetguysComment
28S31B3-8FC8
DaNetguys
You need a programmer, there are many brands, but the cheapest is CH341A (cheapest but not the best).
https://www.youtube.com/results?sear...mer+how+to+use↵
https://www.badcaps.net/donateComment
Thanks for the fast reply hoaca388. So that means that I have to pull the whole MOBO, unsolder the correct chip and then flash it. then resolder it back on.... sheesh... ur asking alot from a 58 year old with shaky hands... so i would need a heat gun(specifically for doing this)???Comment
Hi everybody
could somebody help me unlocking this dell latitude 5520 bios
ST: DXF7SG3 here is my old dump
thank youComment
Good evening. I was finally able to get the bios chip from this soldered to some wires and dump the bios. Are you able to help me unlock and clean it? I hope it dumped right.
Thank you for your help.
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by Jeff'sTechHello everyone.
I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make... -
by YOUCEF4787Hello everyone,
I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
Initial Problem:
The laptop was completely dead, no signs of life, no power LED.
Action Taken:
I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
Current Situation & The Main Issue:
The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly.... -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
- Loading...
