HP BIOS unlock tool
  • Expired
    • Feb 2023
    • 33
    Re: HP BIOS unlock tool
    Originally posted by kolabi
    try this one
    Code:
    After entering BIOS, go to security tab and reset security settings to default!
    Model: HP EliteBook 745 G5
    Serial: 5CG93100X6
    Mac:
    SKIJ: 31JP50EA#ABU
    auildld:
    Board PGWJEOOWBCK3W2
    Feature byte: 3X476J6S6b787H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqhKhkjh.F5
    COA: J4XFW-PN3K20FX83-2JBP8-RX8XC
    ME version: 25525525565535
    try and reply with results
    • hoaca388
      Badcaps
      • Jan 2022
      • 11411
      • Viet Nam
      #1482
      try this one
      Your problem is that you can't extract the complete bios file, you just need to extract the bios and use RC unlocker to be fine
      • kolabi
        • Apr 2023
        • 10
        • France
        #1483
        Originally posted by Expired
        Code:
        Serial: 5CG93100X6
        Mac:
        SKIJ: 31JP50EA#ABU
        auildld:
        tried it , now does not boot or anything (dead)
        • Ademerlac
          • Jul 2023
          • 5
          • Poland
          #1484
          I put HPunlocker on c: but I still have an error: Failed to executed script HPunlocker"
          Plese help.
          • Ademerlac
            • Jul 2023
            • 5
            • Poland
            #1485
            Sorry, did it wrong way
            • Ademerlac
              • Jul 2023
              • 5
              • Poland
              #1486
              I have the trouble to reset my password.
              Unfortunately after used HpUnlocker , the laptop do not start!
              My 2 files bios are attached.
              Please help me to find out what's wrong?
              Is there anything what Im doing wrong?
              Please help
              • hoaca388
                Badcaps
                • Jan 2022
                • 11411
                • Viet Nam
                #1487
                Please help
                Find RC Unlocker .
                • uritech
                  • Jun 2022
                  • Mexico
                  #1488
                  HI, someone can help me to disable absolute persistence module, here are both dump 16MB and 32MB.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11411
                    • Viet Nam
                    #1489
                    Post your request in its correct topic with the serial number.
                      • 20470
                      • kaltmond
                        Default
                        • 13
                        i've a Zbook G9 with Xe and discrete graphic installed. In BIOS there is only UMA and Hybrid option available, so is there a way to unlock the discrete card alone?
                        In my G7 i can set disdrete in BIOS and completely disable optimus, but in G9 no such option available.
                        Ive tried with UEFITool and IFR Extractor with RU.efi to change a Variable but ended with a blackscreen with backlight. reset cmos back to normal again.
                        Any help to unlock the hidden option is appreciated. THX in advance. XD
                        • Slimat
                          • Nov 2023
                          • 10
                          Hi all, real newbie here - lots to read on this topic, but before I get my first problem, which is sure to happen... I just wanted to say thanks to everyone who has worked so hard on this and provided so much fantastic information
                          • RethoricalCheese
                            • Mar 2013
                            • 1517
                            • Estonia
                            #1493
                            Your first problem is that you should be using RCUnlocker instead of this outdated tool
                            • Arkangelus
                              • Feb 2021
                              • 20
                              • Chile
                              #1494
                              I tested this tool with an HP 420 and it removed the password without problems.
                              Thanks a lot!!!
                              • GAV86
                                • Jan 2024
                                Hello. I have a problem with the administrator password on the HP Probook 650 G2. I tried with HPUnlocker and RCUnlocker and the laptop does not work. It turns on, after 30 seconds the fan spins strongly, the screen is always black. Can anyone help me?
                                I returned the password-protected dump, and everything was the same. It seems I initially read the firmware incorrectly...​
                                  Vesko356 commented
                                  Editing a comment
                                  Should work, most probably you didn't program or solder the chip properly. Check surrounding area for moved/knocked components.
                                  Don't use a clip, erase the chip before programming the unlocked dump, use verification.
                              • GAV86
                                • Jan 2024
                                I desoldered the chip and soldered it to the programmer board. I tried other firmware with which the laptop does not respond to the power button. At the same time, my firmware turns it on a little, but with a black screen. Visually I do not see any damaged components and the chip is sealed correctly. When turned on, there is a 3.3V (8 pin) power supply. I'm interested in the correctness of my dump, I'm afraid there's something wrong there.​
                                • DAHOUD
                                  • Sep 2023
                                  • 33
                                  • Tanzania
                                  #1497
                                  I tried to use RC unlocker but come with this error Help please someone with idea
                                    Vesko356 commented
                                    Editing a comment
                                    Use the search engine before asking questions. It has already been commented on in earlier posts.
                                    You MUST:
                                    • Use search function in case someone already answered your request
                                • areylo
                                  • Jan 2024
                                  • Česko
                                  #1498
                                  Could someone help me what to do and how to do it? I bought an HP probook 650g3 laptop and found a locked bios at home. I tried various tutorials, none of them helped. I finally found a forum where I could unlock the bios. I downloaded RCUnlocker v1.0, I move the bin file to it, it says bios unlocked. After restarting the laptop, where I try f10 in the bios, it still needs a password. What am I doing wrong?
                                  Click image for larger versionName:	rcunlocker.pngViews:	0Size:	102.4 KBID:	3204361
                                    Vesko356 commented
                                    Editing a comment
                                    Read the rules please
                                    You MUST:
                                    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                    • Provide a BIOS/EC dump if possible
                                • areylo
                                  • Jan 2024
                                  • Česko
                                  #1499
                                  Machine model number: X4N07AV
                                  Serial number: 5CG7261RTW
                                  board model number: HP 82AA PGDQK00WB832Y2 KBC Version 49.35
                                  bios: P83 Ver. 01.03 5CG7261RTW HPQOEM - 0
                                    Vesko356 commented
                                    Editing a comment
                                    Upload your original bios backup
                                • areylo
                                  • Jan 2024
                                  • Česko
                                  #1500
                                  I don't have any original bios backup. Could I get some advice here or some post here how can I do this?
                                • salim5566
                                  loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                  by salim5566
                                  Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                  06-26-2025, 03:25 PM
                                • zenius
                                  by zenius
                                  12-08-2024, 06:13 AM
                                • Forest79
                                  by Forest79
                                  07-23-2023, 07:39 AM
                                • Kesavan
                                  HP 245 G10 BIOS UNLOCK FILE REQUEST
                                  by Kesavan
                                  Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                  Attached my backup file
                                  SERIAL NO: 5CG4300CNT...
                                  06-16-2025, 06:42 AM
                                • Sebastian Codrean
                                  BIOS file for ASUS F542UN laptop
                                  by Sebastian Codrean
                                  Hello to all of you! I need help with a BIOS file.
                                  The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                  So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                  02-20-2025, 10:25 AM
