HP BIOS unlock tool
  • black0hackers
    • Jul 2020
    • 369
    Re: HP BIOS unlock tool
    Originally posted by peste
    try..
    Still has bios pasword peste!
    • peste
      • 13904
      • ROMANIA
      #702
      also post the MB bios
      • black0hackers
        • Jul 2020
        • 369
        here is it!
        • black0hackers
          • Jul 2020
          • 369
          Sorry, here is orginal file
          • peste
            • 13904
            • ROMANIA
            #705
            try..
            • black0hackers
              • Jul 2020
              • 369
              try..
              password is remove now!
              but have some problem on post (see picture)
              and wifi not detechted!
              • tiamoface
                • Jan 2019
                • 7
                #707
                Hi Gents,
                Can you help please with HP EliteBook 840 G6 bios password removal?
                Tried to remove and soldered chips back on the motherboard but now just caps lock always on and blank screen.
                Attached 2 original dumps 16mb wson-8 and 32mb.
                Thanks in advance!
                • peste
                  • 13904
                  • ROMANIA
                  #708
                  Originally posted by tiamoface
                  Hi Gents,
                  Thanks in advance!
                  try..
                  • tiamoface
                    • Jan 2019
                    • 7
                    #709
                    omg that was quick. Thank you mate. is it service bios and it works on each 840 g6 or my original dumps needs to be changed?
                    • jyg06
                      • Mar 2021
                      • France
                      #710
                      i just bought a HP Probook 645 G2 with the bios locked with unknown password from seller, can you help me?
                      HP PROBOOK 645 G2
                      N° série 5CG7112N0S
                      Version du BIOS : N77 Ver. 01.07 - 11/01/2016
                      Merci
                        • 22241
                        HP PROBOOK 645 G2
                        N° série 5CG7112N0S
                        Merci
                        Use a hex editor, compare the files in this thread to see where the edits were made then you can remove your own password - https://www.badcaps.net/forum/showth...&highlight=645 .Alternatively you can try the HPUnlocker at post #1 ,make sure you make a good backup first.
                        • jyg06
                          • Mar 2021
                          • France
                          #712
                          I would like to have the tutorial to do it because I am a little lost and this without having to unsolder the bios chip that I am unable to do.
                          • fastar
                            • Mar 2021
                            • Spain
                            #713
                            Hi
                            I use the tool but it generate the same file
                            Anyone can help me
                            Is a elitebook 2760p
                            • Didier91
                              • Feb 2021
                              • France
                              #714
                              Good morning all,
                              I received the eeprom programmer (EZP2019) and its software. All for a few euros including postage and it works extra. On the other hand I did not succeed in having a reliable dump with the clamp (with or without charger, with or without capacitance on the power supply (3.3uF and 100nF wired to the shortest (very close to the chip not on the clamp))).
                              So I unsoldered the chip by making myself a piece of copper (end of pipe modeled with the pliers) to have a thermal contact on the 8 pins at the same time and fixed on my soldering iron (80W minimum). After laborious heating, it was perfect. Desoldered and recovered with tweezers in 10s.
                              The chip on the adapter (zero insertion force) then multiple readings (with the EZ2019) to compare them with each other (Compare function of HxD). No differences on the ten reading of the chip. There, the reading is reliable.
                              Drag / drop onto the magic program (A BIG THANKS to RethoricalCheese) and a new unlocked bios is available.
                              3 successive erasures to be sure and reprogramming of the chip with the EZ2019.
                              And multiple rechecks.
                              Between reading, erasing and reprogramming, I did not touch the chip in the socket at zero insertion force in order to be sure all contacts were safe.
                              Re-solder the chip onto the PCB with a soldering iron and you're done!
                              Start and there, the magic happens. Everything works perfectly and goodbye damn password.
                              Thank you all for this very, very informative thread.
                              Didier.
                                • 22241
                                If you can`t unsolder the chip use a sop8 clip. If the chip is a WSON8 then you can solder wires to the pads.If you can`t do that i suggest you take it to a shop .
                                  • 22241
                                  Originally posted by Didier91
                                  Good morning all,
                                  Didier.
                                  great job didier
                                  • HSBunlock
                                    • Mar 2021
                                    • 30
                                    • UK + PAK
                                    #717
                                    thanks all , very helpfull posts
                                    • Chunba
                                      • Mar 2021
                                      • Belgium
                                      #718
                                      Originally posted by grzesiek3108
                                      Probably 3V , but you do not damage chip if its 1.8V (at least i never did) just programmer wont recognize it.
                                      @RethoricalCheese Thx again for explain. I used try HxD when ive gote several SMC.bin files delivered from Hp support to figure out how to create it for myself, but never did
                                      Confirmed : Probook 650 g1 i5 cpu, Desolder, puted on EZP, read bios .bin, just drag and drop .bin dump on your .exe, erase chip and write new created .unlocked.bin
                                      Works great.
                                      Hey grzesiek3108,
                                      I also have an old probook 650 G1 with a blocked admin password.
                                      Would you mind sharing your file with me?
                                      Thx
                                      • peste
                                        • 13904
                                        • ROMANIA
                                        #719
                                        Originally posted by Chunba
                                        Hey grzesiek3108,
                                        Thx
                                        post the backup of the bios
                                          • 22241
                                          Hey grzesiek3108,
                                          Thx
                                          Use the HPUnlocker tool attached at post #1 ,read the instructions.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
