HP BIOS unlock tool
Re: HP BIOS unlock tool
Used the tool for probook 650 g3 .no boot!SORRY WAS BADF CHARGER.Last edited by bachir2004; 11-24-2019, 08:16 AM.Comment
can i use some BIOS Backup Tools to get the dump from a EliteBook 840 G1?
i tried with Universal BIOS Backup Toolkit 2.0
can u check this for me please?Attached Filesif you find these attachements useful please consider making a small donation to the site
But there is no point in doing it like that. You can't program eeprom without using a SPI programmer anyway. So just get a programmer and read it with that.
The other way would be decrypting the password but good luck with that (and share knowledge if you succeed
My Problem is, that i tried serveral Times to dump the BIOS with the CH341a Programmer and all dumps are faulty.But there is no point in doing it like that. You can't program eeprom without using a SPI programmer anyway. So just get a programmer and read it with that.
The question is, can someone Check my dump that i created with the Tool. will this dump Work to Flash them?Comment
Then you need to deal with why it turns up faulty. If you can't read properly, you can't write properly.
What you have to do is:
*Disconnect battery
*Connect charger
*Turn on laptop (Go to F1 screen or whatever you like, doesn't matter)
*Turn off laptop using the power button and DO NOT disconnect charger
*Attach soic8 clip to eeprom
*Read bios.
*Mod bios.
*Write bios.
Turning laptop on and off is very helpful on HP-s.Comment
Okay i give it a tryThen you need to deal with why it turns up faulty. If you can't read properly, you can't write properly.
*Disconnect battery
*Connect charger
*Read bios.
*Mod bios.
*Write bios.
i will Report soon thank you in advance
okay i have desoldered my chip and dumped it with AsProgrammer 1.41 and CH341A Programmer
then i used the HPUnlocker Tool and flashed this Image to the Chip (i ereased the Chip before)
now i have only black screen and Blinking CapsLock Key (5 times blinking)
can someone check my dumps to verify please?
Thank you
Here you areokay i have desoldered my chip and dumped it with AsProgrammer 1.41 and CH341A Programmer
Thank you
After programming, Power on laptop and let it power cycle a couple of times. This is CleanME BIOS also so you need to wait for it to finish everything...Attached Filesif you find these attachements useful please consider making a small donation to the site
THANK YOU SOOOO MUCH!
have u only use the HPUnlocker Tool? i have 2 another Elitebooks can i use this tool to done this?
or have u special mod used?Comment
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
- Loading...
