HP BIOS unlock tool
  • quidep
    • Apr 2020
    • 19
    Re: HP BIOS unlock tool
    Hello all,
    sorry to bother you again.
    Yesterday I tried it again:
    - soldered the original chip back: laptop worked, I could boot W10 from the SSD
    - desoltered again and connected again to CH341A I could finally read out the content without any problems, so now I have a dump
    - created an unlocked bin file, programmed it to the new chip and soldered onto the mainboard: same problem, the LEDs of the caps lock and num lk buttons blink several times, the fan goes on, then the laptop "restarts" again and again. I tried holding several buttons on power on, no luck.
    - unfortunately I managed to break off a pin of the original chip, so cannot try to reprogram it anymore
    - the new chip has the IDs:
    ID(9F): EF7018, ID(90): EF17, ID(AB): 17, ID(15): 6060, the original one ID(9F): EF4018, ID(90): EF17, ID(AB): 17, ID(15): 6060 but both were recognized by CH341A Programmer as Winbond W25Q128FV. Could that be the problem?
    Could you please check, whether my dump and the unlocked file looks OK for you?
    • quidep
      • Apr 2020
      • 19
      The end of the story: I bought a pre-programmed BIOS chip on e**y, the seller sent me 2 pre-programmed chips (main and spare) and also as an alternative, the main chip with the unlocked file from my last post. I tried at first this one and it worked!
      So no idea, what was exactly my problem, maybe there were more than one, but finally it worked
      Thank you for all support and for the unlock tool!
      • vjkomix
        • Oct 2016
        #323
        i did try use thi, it will generate file,but still have bios locked admin pw
        someone explain or help?? need these files unlocked
        • Bonzas
          • 469
          • Indonesia
          #324
          If your file not working, try this. But you need insert DMI manually if this file work.
          • vjkomix
            • Oct 2016
            #325
            i would like to keep original bios file just unlocked
            • Bonzas
              • 469
              • Indonesia
              #326
              i only failed when unlock G5 & G6 series, result almost no display after flash with file generated from unlock tool.
              • IT-Guy
                • Jun 2020
                • 8
                Dear community,
                I want to share my experience with HP 1030 G2 "passworded" notebook.
                First of all THANKS RethoricalCheese for this excellent tool!
                Thanks to other supporters here, helping others to get their (i hope) hardware back.
                Abbreviations:
                NB1 = "passworded" notebook.
                NB2 = working notebook, but slightly another modell (without SureView).
                BIOS Chip: 25Q128JVPQ
                As RethoricalCheese suggested, I have tried to use Raspberry Pi as flasher with software FlashRom. RasPi already have flashrom, but older version (in stable), i had to build a newest version from git to get chip identifiyed.
                You also have to modify /boot/config.txt and uncomment/add dtparam=spi=on and reboot
                As the chip is WSON8 packaged, SOIC8 clip would not work, so i decided to build a "probe" to not leave any soldering traces on the mainboard. Ordered pogo pins and built quick&dirty probe:
                Be sure to not connect to MXIC chip, i't not bios
                Then i tried to read a chip. It was pain in the a..
                Sometimes it said "No EEPROM/flash device found."
                Sometimes it said:
                Multiple flash chip definitions match the detected chip(s): "MX25L6405", "MX25L6405D", "MX25L6406E/MX25L6408E", "MX25L6436E/MX25L6445E/MX25L6465E/MX25L6473E/MX25L6473F"
                First, read the whole topic. There are instructions from RethoricalCheese, follow them: https://www.badcaps.net/forum/showpo...4&postcount=27
                In my case, I disconnected battery, connected PSU, went to bios asking me for a password, switched NB with power button, disconnected PSU, placed a "probe" and connected 3,3V to RasPi (pin 17).
                Even after i triple checked all connections and made sure all pogo pins are on their pads (chip was also detected correct) I got strange behavior,
                also described by someone in topic: all reads produced garbage, md5sum did'nt match:
                Then i looked here: https://www.flashrom.org/RaspberryPi and saw a hint about a decoupling capacitor. Looked into linked doc, it says max. capacity is 10uF.
                Found in my arduino set such a capacitor and soldered it between GND and 3,3V (minus to GND).
                And WOW, it worked like a charm!
                Now transfer a good readout to your computer (file must have extention .bin (!), no spaces/umlauts/cyrillics in full path), drop it on tool's .exe and look for your dump with "_unlocked" suffix.
                Transfer it back to RasPi and flash back to chip.
                And then read again and check md5sum
                Always have original, verified dump!!!
                Read/write takes approx. 160 sec. with standard speed (2000), you can speed up with
                Code:
                [FONT="Fixedsys"]flashrom -p linux_spi:dev=/dev/spidev0.0[B],spispeed=4000[/B] -r orig.rom[/FONT]
                it doubles speed and works. I have not tried more, maybe it can damage chip?
                Unfortunately Unlock Tool was not able to disable Power-On Power ON Authentication.
                RethoricalCheese suggested to replace UserCred section from working Dump. I did so and there was something strange:
                NB2 with same chip worked only WITHOUT decoupling capacitor!!!
                With capacitor all dumps were different! I have no idea why.
                Maybe it helps somebody)))
                • IT-Guy
                  • Jun 2020
                  • 8
                  I have tried to replace UserCred section of passworded dump (NB1) with one from working notebook (NB2):
                  3559 bytes.
                  After power on: power-on authentication, but with credentials from NB2 (defaultuser0 and install). I know password from user "install" from NB2, but it does not match.
                  Questions:
                  1) Where is the password stored? Plain? Hashed?
                  2) NB2 has no power-on auth, so it must be some flag in original dump?
                  3) defaultuser0? Not a user from windows
                  can somebody help me to unlock this original bios (attached)?
                  Second problem: after 5-10 reads i've switched notebook on and saw this:
                  Now i see this screen every time, any chance to get rid of it?
                  Your help is very appreciated
                  • RethoricalCheese
                    • Mar 2013
                    • 1517
                    • Estonia
                    #329
                    You would need a totally clean UserCred section since password is not stored there. Using a clean UserCred just gets you access to bios. After getting there, you need to reset security settings to default. After that, password is fully removed.
                    Just find an unlocked dump in this forum and get that section from there.
                    • IT-Guy
                      • Jun 2020
                      • 8
                      How long is the UserCred section? I'm pretty new to this)
                      I took your 1030G2_OK.bin from 2 or 3 page and it has no Usercred section at all)
                      Digging in progress
                      • RethoricalCheese
                        • Mar 2013
                        • 1517
                        • Estonia
                        #331
                        It ends with hex AA55
                        • IT-Guy
                          • Jun 2020
                          • 8
                          You are the boss man
                          Took unlocked bios from peste (https://www.badcaps.net/forum/showpo...&postcount=238) and replaced intuitive till AA 55)
                          No password!
                          But "Security Device Problem" remains, reset security settings (F10->Security tab) done 3 times, it asks for clearing TPM, F1 F1 for accept, but error comes again and again.
                          I'll try to decript user password from windows, just curious what i entered as pass.
                          ME has pass to, but not critical atm.
                          Just this Security Device nag screen is annoying....
                          • Timbo01
                            • Mar 2020
                            • 7
                            Would this work?
                            Original dump of the left - file after running the unlocker tool on the right
                            https://drive.google.com/file/d/1Cse...ew?usp=sharing
                            It's from a Elitebook 830 G5 and I have attached the dump to this post
                            Last edited by Timbo01; 07-20-2020, 09:17 AM. Reason: Uploaded original dump attached
                            • bidox
                              • Jun 2020
                              • 8
                              • rabat
                              #334
                              hi
                              please help me to unlock this bin bios for laptop hp probook 650 g2
                              • KingBonecrusher
                                • Jun 2020
                                • 28
                                • Netherlands
                                #335
                                Code:
                                MODEL:     HP ProBook 650 G2
                                SERIAL:     5CG7505M0
                                MAC:      80:CE:62:28:CC:81
                                SKU:      L8U47AV
                                FD:       V2/3
                                NVAR ID:    3F
                                BUILD ID:    15WWCIET601#SUUG#DUUG
                                BOARD CT:    PFKCQ00WBA80T
                                FEATURE BYTE:  3Q3X476J6S6Z6b7H7M7Q7W7m7saBaEapaqauawbhdQdUdpdqfSgd.EB
                                UUID:
                                COA:      TY94N-XXXXX-9T9XV-H32GM-XXXXX
                                ME:       11.8.50.3425
                                • pronto
                                  • Mar 2019
                                  • 113
                                  • morocco
                                  #336
                                  thanks but not working
                                  File Type: zip hp_probook_650-g2_patched.rom.zip
                                  not working
                                  • Akintunde
                                    • Mar 2017
                                    • 154
                                    • Nigeria
                                    #337
                                    Originally posted by bidox
                                    hi
                                    Try this and Report
                                    • Timbo01
                                      • Mar 2020
                                      • 7
                                      Has anyone managed to clear the HP Laptop BIOS Administrator password from a 32MB bios?
                                      • baselse
                                        • Jul 2020
                                        • 11
                                        • Netherlands
                                        #339
                                        Yes I did, but after going through the bios menu, there was a second prompt for the admin password which was not removed.
                                        See post.
                                        • Timbo01
                                          • Mar 2020
                                          • 7
                                          See post.
                                          Looks like we are in the same boat. Your laptop layout looks just like mine! Except mine is a WSON package and yours looks to have some legs that a clip and go on?
                                          https://drive.google.com/file/d/1qdT...ew?usp=sharing
