Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
  • betonel
    • Nov 2015
    • 32
    • romania
    Re: Macbook M1 bypass FMM / EFI Unlock
    Originally posted by ebaymonster
    I have 5pcs MBA 2020 m1 and 1 MBP 13 m1 + t203. if you want i can desoldering and make dump.
    It will be great.
    I have tried M1.bin and M2.bin, MBP did not start, it entered dfu mode and did restore with appleconfigurator2, which updated iBoot-7429.81.3. Now it starts but nothing has changed (SN/Activation Lock is still the same - can check SN in diagnostics mode). If I put old dump which was working before with iBoot-6723.50.2 will power on then restart, cycle all over again.
    Data we need might be in ssd NAND, but I think secureboot bits are set in SOC bios rom. We need an easier way to access NAND sysconfig area.
    • mazoot
      iFixit
      • Jan 2019
      • 41
      • Moldova
      Originally posted by Nico Latour
      m1 bin is encrypt! when you decrypt you see serial!!! but change serial in this bin is not working for unlock icloud)
      how about MDM locked M1 with modified serial situation? Did you test ?
      Kill the state in yourself and you will be free like a wind...
      • betonel
        • Nov 2015
        • 32
        • romania
        Haven't found a way (yet) to change the SN for M1 machines. There is no clue SN would be in Winbond SOC rom. Writing content from other machine would stop booting, after dfu restore SN is unchanged. It might be here encrypted, and backed up in ssd nand flash like on iphones/ipads. In the end, can't see the scope of having this SOC chip.. maybe it holds iBoot bootloader code, or act as a backup and SN is encrypted here.
        Another lead to be investigated is to intercept spi communication with the chip in various states of machine: boot.. mdm.. activation lock check.. efi password verification.
        I'll put my logic analyzer at work and keep you updated. Any suggestion is welcomed.
        • mazoot
          iFixit
          • Jan 2019
          • 41
          • Moldova
          Is your m1 have boot secure locked? can you boot from usb etc ?
          • betonel
            • Nov 2015
            • 32
            • romania
            Yes, secureboot is enabled + activation lock. It would be nice to have dump of M1 machine without icloud/mdm one with secureboot disabled and one with secureboot enabled, so we can compare content.
            • .::iRizwan::.
              Banned
              • Apr 2016
              • 63
              • Pakistan
              #26
              Secureboot settings are stored in NVRAM
              you can disable Secureboot and enable USB boot by commands on T2 jailbroken machines.
              • .::iRizwan::.
                Banned
                • Apr 2016
                • 63
                • Pakistan
                #27
                Two commands actually.
                one for Disable secure boot
                and one for Enable USB Boot.
                • .::iRizwan::.
                  Banned
                  • Apr 2016
                  • 63
                  • Pakistan
                  #28
                  some will argue that can be done in a single command
                  yes can but actually these are 2 separate commands.
                  • betonel
                    • Nov 2015
                    • 32
                    • romania
                    #29
                    Apparently after flashing SOC rom I can see external boot device. Who can share working external drive image of BigSur then try to copy it into internal M1 flash and start normally.
                    • HansTodi01
                      • Dec 2021
                      I don't know if this can help. But it is possible to dump every partition mounted in diagnostics mode. There are some Firmware Files (img4) on there. But this probably wouldn't help, right?
                      • betonel
                        • Nov 2015
                        • 32
                        • romania
                        #31
                        How would you do that? Please detail your findings so we can replicate.
                        • HansTodi01
                          • Dec 2021
                          As it turns out, you can download files to an External Storage Device using the built-in Safari. So I also tried if you could upload files from mounted partitions, and yes this work perfectly fine (on some sites it won't).
                          So I quickly coded a Webpage with JSZip that combines all selected files to a ZIP and then starts the download. The ZIP is then saved to the Storage Device using Safari.
                          It would probably work out to just use Google Drive or something, but this was the most local solution (nothing saved on server, basically just download your uploaded files).
                          I used my web server and domain to do this because it seems to require an actual Domain and also doesn't allow PHP Files.
                          There are multiple Partitions on there, which you can see if you go to:
                          Safari --> Settings --> Download Folder --> Select
                          (At the top, where your current folder is displayed, you can click on the dropdown and then select the MacBook to see even more)
                          • betonel
                            • Nov 2015
                            • 32
                            • romania
                            #33
                            Download terminal app in place of safari.app overwrite, close safari.. open again then u re in terminal. Too good to be true, but worths trying.
                            • HansTodi01
                              • Dec 2021
                              I think you can't write to the partitions. But I will try this soon
                              • betonel
                                • Nov 2015
                                • 32
                                • romania
                                #35
                                Sure you can, I have downloaded some tests and it worked. But don't know about overwrite.
                                • ebaymonster
                                  • Dec 2021
                                  • 0
                                  • Ukraine
                                  #36
                                  tomorrow I will have a MacBook Air without blocking /absolutely normal. what do i need to do ?!
                                  1)....
                                  2)....
                                  3)....
                                  • Stephen
                                    Meow Meow MEOW!
                                    • Apr 2020
                                    • 667
                                    Update:
                                    Socrom on MBA 13" M1 does not have SN written whatsoever. If it is written it is coded differently. I should have an unlocked M1 arriving next week
                                    sigpic
                                    MEOWING IN THE IMPOSSIBLE UNIVERSE!
                                    • Nico Latour
                                      Banned
                                      • Sep 2019
                                      • 52
                                      • france
                                      #38
                                      Originally posted by Stephen
                                      Update:
                                      I already said this when you said there is no number in it (m1 bin is encrypted)
                                      • ebaymonster
                                        • Dec 2021
                                        • 0
                                        • Ukraine
                                        #39
                                        has anyone tried to unsolder SSDs and read them? an acquaintance of mine says he can solder them to his phone or tablet and read through ibox.
                                        • qava
                                          • Jun 2018
                                          • 21
                                          • Poland
                                          #40
                                          Hi. I get the 2020 M1 MBP, A2338 chassis 820-02020-11 with UF260 8MBIT-3.0V W25Q80DVUXIE.
                                          Can I do an activation after using T2 T203 programmer?
                                          This model is supported?
                                          • tobeend
                                            Bypass mdm macbook m2 ventura
                                            by tobeend
                                            1. RESET MACOS WITH IPSW
                                            a. Power off MacBook, press and hold the power button to enter Recovery
                                            b. Open Disk Utility, remove Macintosh HD
                                            c. Reboot, connect to the network to Activate Mac.
                                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                            05-26-2023, 07:18 AM
                                          • oxonater
                                            Apple MacBook Pro A2141 16" IC BYPASS
                                            by oxonater
                                            Hi everyone hope all are well
                                            I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
                                            I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
                                            The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
                                            I suppose it's worth noting googling the part package brings up various...
                                            10-23-2024, 11:21 PM
                                          • keats11
                                            T2 Macbook MDM Unlock by S/N change.
                                            by keats11
                                            I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
                                            05-15-2023, 06:46 AM
                                          • envym
                                            by envym
                                            Hi everyone!
                                            06-27-2025, 08:54 AM
                                          • Manlikeissak
                                            M1 MacBook EFI/FMM unlock
                                            by Manlikeissak
                                            Hello everyone hope you all are doing well, I'm posting here since no was interested in my post on "MacBook unlocked!" Topic, so In short I have found a way to test every possible key combination to try and find the combination to open the terminal on fmm/EFI locked M1/M2 machines, the person who found this still refuses to give info, but if hasn't lied about it being a key combination there's a chance we might find it, so to try Evey key combination I've got a digispark attiny 85 which is a small μController, I've written as script to emulate a keyboard and go thru every possible key...
                                            07-02-2024, 11:28 AM
