W370SS Clevo EC + Bios DUMP
  • Conste
    • Oct 2018
    • 235
    Hello Together,
    Has anyone a bios dump for Clevo W370SS?
    Board is 6-71-W3S50-D02A.
    Thanks in advance.
  • peste
    • 12768
    • ROMANIA
    Re: W370SS Clevo EC + Bios DUMP
    Originally posted by Conste
    Hello Together,
    Thanks in advance.
    see here..
    https://repo.palkeo.com/clevo-mirror/
    the password "repo"
    admin "repo"
    • Conste
      • Oct 2018
      • 235
      Thanks for the reply, but I do need a 2 MB EC dump and a 4 MB Bios dump.
      I cannot extract this from the files at this site.
        • 20848
        Open the ALL.rom with a hex editor,click on "Edit" then "Select Block" enter the start offset as 0 and the length as 200000 (200000 in hex is2MB) ,select "Edit" then "Cut" ,make a new file by clicking on "File" then "New" ,right click inside the new file and select "paste-insert" ,or select "Edit" then "Paste insert".Now the 2MB and 4MB are split,just save them both.
        HxD ,there`s a german version https://mh-nexus.de/en/downloads.php?product=HxD20
        • Conste
          • Oct 2018
          • 235
          Thanks, done, but no change.
          Guess it is unfixable (
            • 20848
            There`s a service manual at the same link where you got the bios from https://repo.palkeo.com/clevo-mirror/W3xxSS/ .The SM does include the motherboard schematic
            • Conste
              • Oct 2018
              • 235
              Thanks, I know that.
              I managed to bridge PU9 P2808B0 (which was damaged), the famous Clevo Power On Chip and it ended in charging the battery.
              Starting up was also possible, but not with the Power Button, I had to bridge pwr button manually (PIN3 + 6 of the IC) to GND.
              Unfortunately it only start for some seconds and turns off. Also CPU doesn‘t become warm. I think there is more damage than the power IC or bad KCB flash, and since I do not own a programmer it is garbage -.-
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • MDSI
                HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                by MDSI
                I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                Details:
                Model : HP OMEN 17-an012nf
                Motherboard Part Number : DAG3BAMBAF0 REV : F
                Serial Number (S/N) : 5CD7280D51
                BIOS chip : Winbond W25Q64VSIQ
                Programmer : EZP2023+
                Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                I already...
                07-28-2025, 07:11 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
