Need Bios hp 14-dq DA0PADMB8 rev :F
  • ZAiIN
    • Jul 2017
    • 77
    • libya
    I need bios laptop fo hp 14-dq1037wm
    MB NO IS DA0PADMB8 rev :F
  • peste
    • 12859
    • ROMANIA
    Re: Need Bios hp 14-dq1037wm
    posts the original laptop bios
    • ZAiIN
      • Jul 2017
      • 77
      • libya
      model:opad
      DA0PADMB8f0 rev: f
      • hoaca388
        Badcaps
        • Jan 2022
        • 11809
        model:opad
        DA0PADMB8f0 rev: f
        Can you dump original bios ? If not ,you must flash all this bin files , one by one.
        • ZAiIN
          • Jul 2017
          • 77
          • libya
          What is about ec bios?
          Is it5570e programmable
          • hoaca388
            Badcaps
            • Jan 2022
            • 11809
            I've never tried EC programming, it looks like it's in the I/O. EC files can be retrieved from the bios.
            • ZAiIN
              • Jul 2017
              • 77
              • libya
              Thank you my friend.
              It is work
              • jiyo
                • Sep 2022
                • 13
                • Argentina
                Same computer here (HP 14-dq1038wm, motherboard DA0PADMB8F0 REV:F).
                I've tried all of this four bin files with no success.
                Do I have to program all of them, one after another ? Or program each bin and check if computer turns on ?
                The chip is Gigadevices 25b127dsig. It may be faulty. Do you think I can replace it with Winbond 25q128fvsg ? I've checked datasheets and they look very similar.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11809
                  Yes, you can change them.
                  • jiyo
                    • Sep 2022
                    • 13
                    • Argentina
                    Thank you for replying.
                    When you say "one by one" do you mean to flash each bin until I find the correct one ? Or do I need to flash all of them before turning on the computer ?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11809
                      That is, flash each one, turn on the device to test, if it doesn't work, flash the other one.
                      • jiyo
                        • Sep 2022
                        • 13
                        • Argentina
                        I have tried flashing each one. No success.
                        I replaced the original chip with the 25q128fvsg.
                        Flashed each bin and tested again. No success.
                        The computer power led turns on for a couple of seconds then it turns off, in a loop. No fan, no backlight.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11809
                          Your case just try 16MB bios files, maybe your motherboard still has other hardware errors.
                          • jiyo
                            • Sep 2022
                            • 13
                            • Argentina
                            Could be.
                            But before flashing it the computer turned on and showed a message like "Bios corruption detected". I tried to update bios using a usb drive but it could not finish, always an error was found when verifying the written data.
                            I decided to try flashing the chip with a programmer but got the same errors when verifying. I got a different chip, a winbond. It reads and writes ok, also verifies the written data but the computer does not turn on. Only the power light turns on and off in a loop.
                            Maybe the ics are not compatible ? I cannot find a replacement for the original ic here.
                            • Bloodhoundje
                              by Bloodhoundje
                              03-16-2024, 03:12 PM
                            • JoWed
                              Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                              by JoWed
                              Hello Community,
                              I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                              07-01-2025, 09:32 AM
                            • thxd43
                              Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                              by thxd43
                              Hello, first of all, excuse me, I am using the translator, English is not my native language.
                              I have a Lenovo ideapad 330S - 14IKB laptop.
                              The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                              02-23-2023, 08:37 PM
                            • legendkray
                              BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
                              by legendkray
                              I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
                              07-05-2025, 09:25 AM
                            • AquaMan Ua
                              Problem with PANASONIC CF53 laptop after changing BIOS settings
                              by AquaMan Ua
                              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                              05-17-2025, 09:40 AM
