ThinkBook 15 G2 ARE bios please!
  • tracker1
    • Jul 2017
    • 113
    • romania
    Hi all!
    Can someone help to fix bios for this laptop?
    Mb: FLV3B LA-K062P
    REV: 1.0
    Original dump attached.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11741
    Re: ThinkBook 15 G2 ARE bios please!
    Originally posted by tracker1
    hi all!
    Mb: Flv3b la-k062p
    rev: 1.0
    original dump attached.
    • tracker1
      • Jul 2017
      • 113
      • romania
      Thank you, but same problem, laptop powers on but no picture.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11741
        This bios is extracted from .exe file downloaded from Lenovo homepage, maybe your problem is not related to bios.
        • sebulica
          Beginner
          • Mar 2014
          • 50
          • Romania
          Lenovo ThinkBook 15 G2 ARE no image after bios update
          As the title implies,i have a Lenovo ThinkBook 15 G2 ARE with no display after a bios update made by windows trough optional updates.The laptop charges the battery,recognizes the charger (hopefully),starts up but has no image on screen.I have tried rewriting the bios with a few dumps i have found on the forum and outside of it but nothing changes.
          So,when i press the power button,the power led,FnLock,CapsLock and NumLock led lights up for 2 seconds then the CapsLock and NumLock turn off and just the Power and FnLock remain on....and nothing happens after that.If i let the laptop stay on for a while,the fan starts spinning as the processor heats up.
          I have the 5v 3v3 and other power supplies on for cpu,ram,EC etc.
          I suppose it's bios related issue or EC firmware corrupted.I can assume the EC did not update but the bios did and now they are "incompatible".So if there is anyone with an older version of bios to try it i would be glad if someon shared it ....or any suggestion would be great.
          I will attach the current bios on the flash,maybe someone can help me out...
          Cheers.
          • SiO2
            • Apr 2022
            • 24
            Hi, I have a ThinkBook 14 G2 with exactly the same behavior. Already tried to flash a few different BIOS images but no change.
            Did you manage to fix it in the mean time?
            Cheers
            P.S.: Attached the BIOS and the EC(?) dumps
            • SiO2
              • Apr 2022
              • 24
              Update: The smaller firmware was for the PD controller. After flashing the EC with a fresh version extracted from the Lenovo Update file... nothing changed.
              • jozlar
                • Mar 2022
                • 59
                • tbilisi
                Please remove the built-in ram, if I do it with the spd removal tool, it doesn't come out at all, maybe you can help me ThinkBook 15 G3 la-k062p please help me.
              • Laboratorio JG
                • Apr 2025
                • 20
                • Colombia
                Can you help me disable the VRAM on this Lenovo? I tried to find a schematic and boardview to disable it by moving the OBRAM_ID resistors, but without those files it's difficult. So, I want to know if you can help me disable the VRAM through the BIOS. Thank you very much in advance. By the way, the BIOS I uploaded is in good condition. It provides video, recognizes SDDs, and logs into Windows normally. The problem with the machine itself is that it displays colored lines when rendering.
                Model: THINKBOOK 15 G3 ACL
                Mfg Date: 2022/01/14
                S/N: MP26JF6Z
                MTM: 21A4007NLM
                MO: MPNXB212400L
                Board Model: GLV3B LA-K062P
                REV: 3.0
                2021-01-11​
                • joshAU
                  BIOS file for N550JK (original dump attached)
                  by joshAU
                  Hi all.
                  I'm looking for a BIOS file for an Asus N550JK.
                  I have a Asus R552J, which I believe is identical to the Asus N550JK.
                  I downloaded the latest BIOS (210) for the R552.
                  It is named N550JKAS.210.
                  The BIOS file is however only 6mb in size.
                  I've read the chip with a CH341A programmer and verified the file.
                  That file is actually 8mb in size.
                  I'm wanting to remove the BIOS password from this unit.
                  It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                  08-09-2022, 08:06 PM
                • kingiii
                  downloaded bios is smaller than the original bios dump
                  by kingiii
                  Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                  Thank you very much
                  06-07-2025, 04:21 PM
                • miccodan
                  Bios for Dell Inspiron 7573, laptop wont post, original bios attached
                  by miccodan
                  Device: Laptop
                  Brand: Dell
                  Model: Inspiron 7573 2-in-1
                  Service Tag:1G8B6P2
                  Board number: kylo ren 15 16841-1 H7TJX
                  Symptoms: With original bios the laptop will not post, keyboard and power light flash on/off upon pressing power button and no fans spin. Attempted to use bios found on here and with other bios the laptop powers on and fans run at full speed and stays running but will not post.
                  original bios is attached. Many thanks in advance!
                  Badcaps - Capacitor Search Engine & Electronics Repair Forum
                  12-08-2023, 06:39 PM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • bondminer009
                  Need Bios for Latitude 7650 (No Original / dump bios file)
                  by bondminer009
                  Good Evening,
                  Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                  Thank You
                  Salam,
                  Three
                  11-12-2024, 07:48 AM
