Dell 7540 8fc8 password
    Re: °
    Originally posted by mediadoctor View Post
    I'm use CH341a with flash verify. But after flashing the notebook restart always after ~20 seconds and screen stay black
    Try and be careful with the things mentioned in my previous post.
    Become a Badcaps supporter
    Thanks to all supporters.​
      Re: °
      Thank you Vesko356, but the same after flashing
      I flash my dump and this work, but bios locked
      Have you unlocked bios from another dell 7540?
        Re: °
        The unlocked bios is OK. As I said, you are obviously making a mistake somewhere, in my opinion it is most likely in the programming process of the chip, that is why I said to do a proper verification, the ch341a is well known for the problems it creates, and this is especially true for large chips like the 32mb.
        In addition, it is good to wait a little longer at the first boot after programming the chip with the unlocked bios, because the first start in this case is much longer than usual.
          Re: °
          Wait time after flashing about 15 min., but many restarts and black screen
          Have you another unlocked bios for 7540?
            Re: Dell 7540 8fc8
            Originally posted by drefo View Post
            Hello here is the bin file that worked for me, thanks again
            This file work! But very long start bios.
            Can you change it?
              Re: Dell 7540 8fc8 password
              Things don't work that way, you can't take a dump from someone else's machine and put it on yours just like that and expect everything to be fine.
              I'm sorry but since you didn't even bother to explain, did you try again to do everything I told you in a way I told you it should be done, I have no intention of helping you any further.
                Re: Dell 7540 8fc8
                Can you change it?
                Hello, The BIOS you used hasn't cleaned the ME region, that can't work.
                I don't want to upset Vesko356 either, since he tried to help you.
                But you should already use an ME region cleaned BIOS, otherwise it won't work.
                Good luck with the ME Cleaned Version of
                https://www.badcaps.net/forum/showpo...9&postcount=12
                  Re: Dell 7540 8fc8
                  [QUOTE=Markus1741;1211921]Hello, The BIOS you used hasn't cleaned the ME region, that can't work.
                  Thank you all!
                  Markus1741 you are the best, your version work correct!
                    I have locked Precision 7540 with password FKS3P13-8FC8
                    Can someone help me?
                      Hello you must read your chip bios and upload the bin.
                        I have Dell 7540 with password bios, can you remove please?
                          Please read the rules before posting,you must post the service tag !
                            Sorry,
                            My service tag is: 102R453
                              Hello can you help me please, I have a Dell 7540 with password Service Tag: 3XP4Q13-8FC8 thank you.
                                here
                                  Originally posted by volinakis View Post
                                  here
                                  Hi, thank you! it's working, but I have a problem with programming the service tag. It is not saving.
                                  I tried to setup and save, and after reboot still had the same empty space.
                                  Can you help me please how to resolve this issue? Thank you.
                                    try this clean ME version.
                                      Hello you can also try this file once ...
                                        Hello everyone! Please I need to unlock DELL Precision 7540 BIOS, here is the dump! Thanks a lot!
                                        ST: 52R8633
                                          ST: 52R8633
                                          Try ...
