samsung NT300E5Q-LD34 BIOS HELP ME
  • hyunsoo
    • Jul 2021
    • 9
    • south korea
    Hello
    I need help
    MODEL:
    SAMSUNG NT300E5Q-LD34
    BA41-02501A
    power on
    no screen
    bios needed.
    please help
  • zenny95
    • Aug 2017
    • 28
    • romania
    Re: samsung NT300E5Q-LD34 BIOS HELP ME
    Try
      • 21692
      • Kiberge
        Samsung LH82QENELGC/EN Help needed - Static line on screen
        by Kiberge
        HI guys!
        I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
        I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
        the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
        This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
        04-22-2024, 11:28 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Zeedu
        samsung NT110S1J bios bin needed pls
        by Zeedu
        helio freinds someone should help me with this bios
        samsung -NT110S1J-K14WS
        s/n = 0GAJ91AFC00432K
        board no. LIBERO-11
        BA41-02396A
        i attached the backup...
        09-17-2025, 03:58 PM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • mitchw
        HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
        by mitchw
        Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
        After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
        After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
        I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
        04-29-2025, 03:45 PM
