HP 850 G3 BIOS dump, view ACPI tables?
  • dualtrace
    • Jan 2022
    • 9
    I have a 16MB data dump from a desoldered corporate HP Elitebook 850 G3 main BIOS chip, taken using a CH341a programmer. This dump contains a password I have no access to.
    I have a fresh BIOS chip, loaded with a clean BIOS for the matching product ID and motherboard number.
    I'd like to find and save any SLIC &/or MSDM, ACPI tables contained in the dump from the desoldered chip so that I can if necessary, modify the fresh BIOS chip's contents to preserve the machine's existing Windows 11 installation's licensing/activation etc.
    Searching the dump using just a plain hex editor, I can't locate anything that shows where these tables are stored.
    I did see MSDM and SLIC tables using acpidump on the running machine before desoldering, just, no idea where the info resides inside the chip dump.
    What tools would I be best using for this?
  • zyze
    • Jul 2020
    • lietuva
    Re: HP 850 G3 BIOS dump, view ACPI tables?
    hello Maybe someone can help me. I have a hp 850 g3 and I made a mistake while reading the bios file. I did not save the scanned file in the trash. And then I deleted it. Now I try many bin files and none of them work. When I turn on the headset spins loudly and the screen is black.
    how can i restore the bios file? Thank you
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • haitham sharabati
      by haitham sharabati
      Hello engineers 😀,
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      💀 Problem:😅
      08-07-2025, 04:54 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
