unlock bios for dell latitude 3520
  • Weelcup
    TopTech
    • Oct 2017
    • 307
    Originally posted by hoaca388
    3.4. Dell
    Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
    See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
    Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
    Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
    Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
    Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
    Note: There is no publicly available 8FC8 generator available at the moment.
    The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
    8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
    Thanks a lot
    All sorted
    • ridouane
      • Mar 2019
      • 37
      • casablanca
      #402
      looking for bios bin file
      Cyborg-L15 MB TGL 213047-1
      DELL LATITUDE 3520
      MFG YR:2021
      ST:JWK4HG3
      EX:43327583571
      • LBTT1121
        • Nov 2024
        • 1238
        • Việt Nam
        #403
        DELL LATITUDE 3520
        MFG YR:2021
        ST:JWK4HG3
        EX:43327583571
        try and feedback
        • ridouane
          • Mar 2019
          • 37
          • casablanca
          #404
          many thanks many thanks many thanks, my dear LBTT1121
          it worked.​
          • bshw
            • Jun 2025
            #405
            Hello guys,
            Could someone please help me with removing the password and disable Absolute from the attached BIOS dump:
            Model: Dell Latitude 3520
            Mobo: Cyborg L15 TGL New Load SW MB, 213277-1
            S.T.: 3LR59S3
            Thank you!
              • 22264
              Originally posted by bshw
              Hello guys,
              S.T.: 3LR59S3
              Thank you!
              here
              • bshw
                • Jun 2025
                #407
                Originally posted by SMDFlea
                here
                Thank you SMDFlea! Works like a charm.
                • vovan77795
                  • Feb 2021
                  • 20
                  • Украина
                  #408
                  Hi. Please fix my dios dell latitude 3520. It does not turn on.
                  ST: HF86ML3.
                  Motherboard 213047-1
                  • The_Memory_Guy
                    • Jul 2025
                    • 10
                    #409
                    HI Guys, need some help with this please, its a Dell Latitude 3520, originally it had bios password lock on it.
                    I have had the Bios chip on and off the board about 20 times time and I am really tired of doing it.
                    I made a mistake with the original bios file because I read it as a 16MB Chip at 1.8V rather than 32MB chip at 3.3v, I subsequently erased and wrote to that chip, I only realized this when I was about to post on the site asking for help as to why my system is dead, I thought OK now I now what the issue I can try work with what I have now and set about trying to rebuild the file.
                    I had a a few of these laptops and one of them had a unlocked bios, I downloaded the unlocked bios and tried to merge it with the locked one to no avail.
                    All I would get is manufacturing mode, no matter how many times I entered the service tag in the bios it would not work, eventually I would press alf+f (on screen instruction to exit manufacturing mode)and to the service menu where i could enter service tag (if never entered in bios previously) , but could never get past accept/continue, it would just beep and never accept the service tag and to get out of manufacturing mode (alt+ fn+x, nothing worked), then the system would lock me out of F2 (bios) or F12 (boot options) and constantly load to this service menu until I remove the chip and re-flash, once I would re-flash chip it would reset and I could get into bios/boot menu.
                    I took pictures previously of the Bios Screens of both machines (prior to doing anything) and realized the one original half I did have was bios version 1.37 and one was 1.38, spent another couple of days trying to resolve that, eventually got it with all data preserved in 1.38 version, but still no joy, same behavior.
                    I have spent the last couple of days trying to bypass and enter the service tag via the Dell Asset utility via botting to USB and running the program from there but no joy. Cant this utility to boot via USB however I structure the files.
                    So basically I'm thinking let me just start from scratch, let me post the board revision number or board number and someone can help me build a file with the correct service tag and express service code. I do have the UUID and Mac addresses if required, nut not the complete original bios.
                    Can someone tell me if this possible, I think the need the board number, can someone tell me where its is?
                    If anyone has got nay ideas, please let me know
                    I've sent a whole week on this and feel like smashing up this board and laptop!
                      • 22264
                      Post the laptop service tag and the motherboard model number, such as Cyborg L15 TGL New Load SW MB, 213277-1
                      • The_Memory_Guy
                        • Jul 2025
                        • 10
                        #411
                        Cyborg-L15 MB TGL NEW PD 4C52D$KA 213047-1
                        Dell Part Number: 03WMC
                        Service Tag: 826KQL3
                        • vovan77795
                          • Feb 2021
                          • 20
                          • Украина
                          #412
                          Привет. Пожалуйста, исправьте BIOS моего Dell Latitude 3520. Он не включается.
                          ST: HF86ML3.
                          Материнская плата 213047-1.
                          Hi. Please fix the BIOS of my Dell Latitude 3520. It won't turn on.
                          ST: HF86ML3.
                          Motherboard 213047-1.
                          in English please...
                          • vovan77795
                            • Feb 2021
                            • 20
                            • Украина
                            #413
                            Hi. Please fix my bios dell latitude 3520. It does not turn on.
                            ST: HF86ML3.
                            • LBTT1121
                              • Nov 2024
                              • 1238
                              • Việt Nam
                              #414
                              ST: HF86ML3.
                              try and feedback
                              • vovan77795
                                • Feb 2021
                                • 20
                                • Украина
                                #415
                                Originally posted by LBTT1121
                                try and feedback
                                It didn't help, the processor must have broken.
                                  • 22264
                                  try this one https://www.badcaps.net/filedata/fetch?id=2129241
                                  • The_Memory_Guy
                                    • Jul 2025
                                    • 10
                                    #417
                                    Unfortunately it did not work, it allowed me enter service tag, even get past the service menu by accepting the service tag number, but would not get out of manufacturing mode
                                    • The_Memory_Guy
                                      • Jul 2025
                                      • 10
                                      #418
                                      Originally posted by satishkumar
                                      Re: unlock bios for dell latitude 3520
                                      you asked me for the board number then gave me the wrong bios, i don't know if your taking the piss or genuinely trying to help
                                        SMDFlea commented
                                        Editing a comment
                                        No, i do beleive he was actually trying to help
                                    • The_Memory_Guy
                                      • Jul 2025
                                      • 10
                                      #419
                                      try and feedback
                                      Cheers, your bin file worked a treat, I wish someone would make it clear you need to match your board number to the correct bin file. Would make life easier and save a lot of questions.
                                      • alvin dionisio
                                        • Oct 2020
                                        • 19
                                        • Philippines
                                        #420
                                        Pls. help to unlock bios dell 3520
                                        • Godfather79
                                          Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                          by Godfather79
                                          Hello everyone in the community
                                          Dear Sir,
                                          I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                          Problem details:
                                          * Model: Dell Latitude 5520.
                                          * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                          * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                          * Service Tag: (Enter your actual Service Tag from the laptop here)
                                          * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                          11-08-2025, 10:04 AM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • Jeff'sTech
                                          Dell Latitude 7420 BIOS Unlock Gone Wrong
                                          by Jeff'sTech
                                          Hello everyone.
                                          I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                          11-08-2023, 03:30 PM
                                          DELL Latitude 3520 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 3520 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3520 boardview and 3520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3520...
                                          09-07-2024, 01:30 AM
