Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
  • aminemsaken
    replied
    Originally posted by Vesko356
    πŸ†•β€΅
    thx but power led blinking and fan turn processor work but black screen with my old bios and with new bios πŸ˜₯
  • Vesko356
    replied
    Originally posted by aminemsaken
    please bios my laptop lenovo ideapad 3 15ALC6
    S/N : PF32D5HT
    MO : PF9XB1724032
    MTM : 82KU006DSP
    MFG DATE :2021/07/24
    Board: HS461$HS561$HS761 NM-D521
    2020 - 12 - 11 REV 2.0
    i upload photo and old bios
    πŸ†•β€΅
  • aminemsaken
    replied
    S/N : PF32D5HT
    MO : PF9XB1724032
    MTM : 82KU006DSP
    2020 - 12 - 11 REV 2.0​
    commented on 's reply
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
  • aminemsaken
    replied
    please bios my laptop lenovo IdeaPad 3-15ALC6
  • gliecer
    replied
    DMI transferred from your old bios backup:
    Thank you very much,
    I really didn't know why I couldn't change the information. I was validating your file and if there is DMI information in the sector 0x1000 to 0x2FFF, but your new BIOS file is encrypted on BC base and mine changed the encryption key to 54, FF, etc. I also noticed that it has more information at the beginning. Which method do you use?. Thanks for the help as all the information is in the BIOS. It seems to me that the motherboard was at some point replaced.
    πŸ˜€πŸ˜‰
  • Vesko356
    replied
    Originally posted by gliecer
    Model: Ideapad3 15alc6
    MO: L39311C18696
    MTM: 82KU00YYUS
    MFG DATE: 2021/12/18
    FACTORY ID: T
    S/N: PC295DZN
    2021 - 05 - 08 REV 3.0
    Vesko356
    NOT work
    7. Copy 0x0520000 into Seletion start and 0x05207FF into selection end ,then click on OK
    10. Click back to the oldbios.bin tab and make a new selection (step 6) with 0x062D000 and 0x062D03F and follow steps 8 and 9 again.
    I'm trying this one but I'm not succeeding either
    publication # 52
    bios extracted from Lenovo support page for ideapad 3-14ALC6, ideapad 3-15ALC6, ideapad 3-17ALC6, V14 G2-ALC, V15 G2-ALC
    DMI 1000 - 2FFF
    Thank you for helping me.​
  • gliecer
    replied
    MO: L39311C18696
    MTM: 82KU00YYUS
    FACTORY ID: T
    S/N: PC295DZN
    Vesko356
    NOT work
    publication # 52
    DMI 1000 - 2FFF
  • Vesko356
    Upload the file here so we can see what you were able to create and if it was correct or not.
  • gliecer
    replied
    Originally posted by peste
    you have everything you need at post#52..use the HxD program that you can find for free...introduce both bios into it (the original laptop and the one from post#52), copy the DMI interval (from post#52) from the laptop bios to the virgin bios...(copy-paste)...and save...
    Hello good morning,
    I did indeed follow the steps of publication # 52 (. How to make a macro script) and replace the following fields in the new BIOS.
    I saved and installed the .bin.bak file on the laptop but it doesn't work. (If it turns on but the DMI information is not)
    I don't have a healthy backup BIOS. I only have the backup after being corrupt. maybe the DMI information was lost because the BIOS was corrupted.
    There is another way to insert the DMI information into the new BIOS or there is no longer a solution πŸ˜₯
  • peste
    replied
    Good morning, I'm trying to create the DMI but I can't, I think I'm missing information. Vesko356 hoaca388 could you help me please.
    MO: L39311C18696
    MTM: 82KU00YYUS
    FACTORY ID: T
    S/N: PC295DZN
    I am attaching the BIOS backup that is working after reviving it 😁 and the damaged BIOS backup before erasing and installing the stable BIOS.
    Thanks for the help, I thought I wouldn't be able to use it again.
  • gliecer
    replied
    MO: L39311C18696
    MTM: 82KU00YYUS
    FACTORY ID: T
    S/N: PC295DZN
  • baiceanu_stefan
    replied
    Re: Bios pleaze
    DMI 1000 - 2FFF
    I can confirm that it is working on nm-d521 rev 3.0 ideapad 3-15alc6 type 82ku. THX
  • Vesko356
    replied
    Originally posted by sleandru
    ideapad 3 15ALC6
    dont have original dump,
    AMD RYZEN 5 5500U - RADEON GRAPHICS 2.10GHZ
    MO: PE9012325055
    MTM: 82MFS00100
    SN: PE08VCFX
    Latest up to date virgin bios (GLCN52WW - 15 Feb 2023) along with the DMI offsets is attached at post #56​.
  • sleandru
    replied
    ideapad 3 15ALC6
    MO: PE9012325055
    MTM: 82MFS00100
    SN: PE08VCFX
  • islamfouda
    THANKS A LOT Martindlm
  • heccrbq1
    replied
    Hello. Can you help me with the BIOS?
    Lenovo IdeaPad 3 15ALC6
    MTM 82ku0020re
    HS461&HS561&HS761 NM-d521 rev 3.0
    2021-05-08
    ​​​​​​​Ryzen 3
  • bladezru
    replied
    Re: Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
    Originally posted by bladezru
    thanks, but still not working.
    Is maybe the chip broken, if i try to verify the chip then i get every time different memory address
    HTML Code:
    Verify memory...
    Verification error on address: 00000296
    Execution time: 00:00:00.033
    Current programmer: CH341
    19:53:11
    Verify memory...
    Verification error on address: 000000AE
    Execution time: 00:00:00.031
    Hi guys, I did it
    i had some small disconnects all the time on my usb ch341 i didn't realize and that was the reason why the memory was corrupted.
    I tried with another laptop and it works.
    and sorry, I know this post is not supposed to go here. But just wanted to thank you all for your great help.
  • peste
    replied
    Re: Bios pleaze
    Originally posted by qonma
    ideapad3 14 alc6
    sn PF3GP94C
    BACKUP BIOS
    DMI 1000 - 2FFF
  • qonma
    replied
    Bios pleaze
    ideapad3 14 alc6
    sn PF3GP94C
    BACKUP BIOS
  • Marc97
    lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
    by Marc97
    hello there,, anyone who can help us to have bios for LENOVO
    HS461 HS561 HS761 NM-D251 REV 2.0
    I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
    i attached the .CAP may you can help us also to trim it.....
    12-03-2022, 05:51 PM
  • macabook
    πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
