Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
  • FachiroDiStriscia12
    • Mar 2023
    • Italy
    #141
    Originally posted by peste;n353[ATTACH=JSON
    {"data-align":"none","data-size":"full","title":"Schermata_20241230_171518.png","data-attachmentid":3538155}[/ATTACH]8149]
    what didn't you understand??write the bios on the chip from post #56..you also wrote the DMI interval there...what's the problem?...the bios is ok...
    Ok thanks ♥️, I'm gonna write the bios I have just made.
    Anyway don't want to be rude but the post #56.. doesn't contain any bios file put as attachment.
    As you can see from my screenshot
    • peste
      • 12290
      • ROMANIA
      #142
      what you posted, mine is post #61...on page 3 of this thread is post #56..look a few posts back..a post I made with bios extracted from the update on the site..search for it and write it...
      • aaugus
        • Apr 2015
        • Slovenia
        #143
        Hi. Can you please fix bios for :
        IdeaPad 3-15ALC6 Laptop - Type 82KU
        SERIAL : PF4B4L23
        Thank You. Ale
        • hoaca388
          Badcaps
          • Jan 2022
          • 11331
          • Viet Nam
          #144
          SERIAL : PF4B4L23
          Thank You. Ale
          • aaugus
            • Apr 2015
            • Slovenia
            #145
            Thank you for the file. Do I have to inject DMI into file ? Because i only got black screen. No post. Power light is on (no blinking) And the fan spins for a 5 seconds.
            B.r. Ales
            • hoaca388
              Badcaps
              • Jan 2022
              • 11331
              • Viet Nam
              #146
              B.r. Ales
              DMI has been fully added to the new file. Find hardware problems.
              • stefanotot
                • Feb 2025
                As the rest of you here, I'm getting no screen output, caps and Fn-lock led's working and power button led flickering. Holding bios recovery button or novo button (small hole next to power led) results in two short beeps and nothing else.
                Lenovo Ideapad 3 15ALC6
                MO: PF9XB2326036
                MTM: 82KU0075RM
                S/N: PF3LD616
                Chip: Winbond 74M12JWSIQ 2204
                HS461&HS561&HS761 NM-D521
                2021-10-26 Rev 3.0
                Don't have access to old bios, and I don't know my way around hex editors so I would be grateful if someone could copy my DMI info onto a virgin bios. Thanks in advance!
                P.S. I don't have a programmer at all. Is this possible to do with only a USB stick by forcing bios recovery mode somehow, or am I going to have to get a programmer and dump my bios old somehow that way then flash new using that DMI? (I was unable to access bios through every option like novo button, Fn+R etc., I corrupted my bios somehow after deleting windows EFI partition, which is odd as deleting SSD partitions shouldn't affect bios but whatever, all symptoms seem to be pointing to bios corruption)
                  • 20397
                  MO: PF9XB2326036
                  MTM: 82KU0075RM
                  S/N: PF3LD616
                  2021-10-26 Rev 3.0
                  As the recovery method hasn`t worked you will have to make a backup using an SPI programmer. The DMI can be transfered from your backup to a virgin bios.
                  • stefanotot
                    • Feb 2025
                    Hello, since my last post I bought a CH341a Mini-Programmer from Ali-Express and I just now tried to read the old bios from it, however whenever I try to read, it gives back FFFF values, or ID Unknown Error (see screenshot). I read up a bit on this and after making sure that the clamp pins are correctly contacting the bios chip and after trying with every driver I found, I stumbled upon a video where the guy says that these values mean the bios chip is completely empty and there is no old bios on it. Any tips on how I should proceed?
                    • peste
                      • 12290
                      • ROMANIA
                      #150
                      The bios chip must be unsoldered from the board before writing or reading..
                      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                      solder wires between the programmer and the bios chip..​
                      here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                        • 20397
                        The bios chip is 1.8V ,did you get a 1.8V adapter with the programmer. The ID Unknown Error is because the 74M12JW is not supported by the programmer software. Use NeoProgrammer or ASProgrammer software and choose W25Q128FW manually, don`t use the Auto-detect. Also read what peste said, if you have the tools to desolder the chip or solder wires instead you will have a better chance of making a good backup.
                        • stefanotot
                          • Feb 2025
                          Thank you! I desoldered it however the video was a little outdated in my opinion so I found this one which helped me more, and might help someone else as well in the future: https://www.youtube.com/watch?v=z9uLPo9QAY8
                          I was able to read the chip (it ID'd it automatically without me finding it manually) and have attached the old bios in this reply. As a last request, I would be grateful if someone could transfer my DMI info, thank you again!
                          • peste
                            • 12290
                            • ROMANIA
                            #153
                            you have everything you need at post 56
                            the bios from post # 56 is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
                            select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
                            • Hugh Mungus
                              • Apr 2025
                              • Slovakia
                              #154
                              Hello, guys. I'm sorry, but I'm a complete idiot about it. I absolutely don't know how to modify bios.cap. I can handle how I get it on the chip. But I don't have a bios backup, as it turned off the laptop during the update.
                              IdealPad 3-14ALC6 (82KT)
                              PF33LFAS
                              82KT00GHCK
                              I try one in this thread, but still dont work
                              Thank you very much
                              • peste
                                • 12290
                                • ROMANIA
                                #155
                                PF33LFAS
                                82KT00GHCK
                                Thank you very much
                                post the contents of the bios chip even if it is corrupted..
                                • Hugh Mungus
                                  • Apr 2025
                                  • Slovakia
                                  #156
                                  I believe, that you mean this
                                  • peste
                                    • 12290
                                    • ROMANIA
                                    #157
                                    you have everything you need at post #52..
                                    • Hugh Mungus
                                      • Apr 2025
                                      • Slovakia
                                      #158
                                      Thank you. It works. But please how I can have my original serial number?
                                      Plus now I can´t use more than 512mb for graphic (bios setup-I have 20 GB RAM). Before I could do it to 2 GB for graphic.
                                      Thank you one more time and I will donate for 100%.
                                        • 20397
                                        Copy your DMI to the new bios using the attached script, read the README.txt file for instructions.
                                        • Keroro Gunsou
                                          • May 2025
                                          • 5
                                          • Philippines
                                          #160
                                          hello sir, good day, my Lenovo 3 Ideapad 14ALC got bricked. only the ESC and CAPSLOCK and power button lights up, no display. can this bin file help?what to do with the bin file?ill be glad to donate if you could help me thank you
                                          • Marc97
                                            lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
                                            by Marc97
                                            hello there,, anyone who can help us to have bios for LENOVO
                                            HS461 HS561 HS761 NM-D251 REV 2.0
                                            I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
                                            i attached the .CAP may you can help us also to trim it.....
                                            12-03-2022, 05:51 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
