Lenovo y540-17IRH IT8226e-192
  • Lukosiukas
    • Jul 2018
    • 106
    • Lithuania
    Hi, got a Lenovo y540-17IRH (board NM-C531) with broken charging port. Found out that superio IT8226e-192 has internal short (thanks lenovo for great charging design ), found out that it's needs to be programed. Maybe someone has KBC bin and/or knows where i could get pre-programmed ?
    p.s. got access to Vertyanov programmer, but didn't found this IT on support list, maybe someone knows if that will work for my job ?
    • 21981
    Re: Lenovo y540-17IRH IT8226e-192
    Solder on a new blank chip,it will program itself at first boot
    • Lukosiukas
      • Jul 2018
      • 106
      • Lithuania
      Ok, ordering it right now. Hoping for the best. Thankyou for assistance and information.
      • angel-boy
        • 550
        • Romania
        any news ? i have a identic one
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          Common issue. Sometimes pch dies aswell.
          • Lukosiukas
            • Jul 2018
            • 106
            • Lithuania
            Good news, replaced the IT8226e-192, works once again Thankyou all for your assistance.
            • Luskitas120
              • Mar 2022
              • 3
              • Paraguay
              Hello Sir, how are u?
              I have the same issue with a notebook lenovo Y540 i`m from paraguay and here the support even exist.
              So i have the same problem, the charger has internal shock and burn this component in mother board, but i cant find the same component. The script on the component in my legion is this right below, and the component i found in alixpress is this.
              LENOVO LENOVO
              IT8226E-192 IT8226E-192
              2002-BXA 1846-BXA
              S17YVA S16DVA
              L003 L003
              So this difference maybe will dont work?
              Thank you very much in advance
              • Luskitas120
                • Mar 2022
                • 3
                • Paraguay
                Original component
                lenovo
                it8226e-192
                2002-bxa
                s17yva
                l003
                component find in aliexpress
                it8226e-192
                1846-bxa
                s16dva
                l003
                • peste
                  • Dec 2016
                  • 13656
                  • ROMANIA
                  Originally posted by Luskitas120
                  Original component
                  lenovo
                  it8226e-192
                  2002-bxa
                  s17yva
                  l003
                  it8226e-192
                  1846-bxa
                  s16dva
                  l003
                  in my opinion it should work..check the chip to solder and leave the laptop on for at least 30sec, after starting ..
                  • Luskitas120
                    • Mar 2022
                    • 3
                    • Paraguay
                    Oook! Thx very much!! i will try and comeback here later to tell the result!
                    • jbccccc
                      • Jan 2022
                      • Philippines
                      Hi! any updates if replacing it with a chip that is not exactly the same works. I have the same problem with my y540-15IRH the chip that is shorted is
                      IT8226E-192
                      1919-BXA
                      S16YRA
                      L003
                      but what i can only find online is only the same on the 1st and last line
                      IT8226-E
                      1914BXA
                      S16TSA
                      L003
                      would it work?
                      • ahmaweed
                        • Jan 2023
                        IT8226E-192
                        1919-BXA
                        S16YRA
                        L003
                        IT8226-E
                        1914BXA
                        S16TSA
                        L003
                        would it work?
                        Hi!
                        I have the same question. Did it work out?
                        mine is:
                        IT8227E-192
                        2006 CXA
                        SK0WAB
                        L005
                        The closest I could find is
                        IT8227E-192
                        2007 CXA
                        SK0Y8B
                        L005
                        Will it be work??
                        Some solder fell in the casing and it fried the chip before I could do anything
                        • peste
                          • Dec 2016
                          • 13656
                          • ROMANIA
                          Originally posted by ahmaweed
                          Hi!
                          mine is:
                          IT8227E-192
                          2006 CXA
                          SK0WAB
                          L005
                          IT8227E-192
                          2007 CXA
                          SK0Y8B
                          L005
                          Will it be work??
                          i think it's ok...try it..
                          • forespec
                            • Nov 2012
                            • 14
                            • India
                            In my case I accidentally shorted adapter I'd pin with 20v. Which shorted sio internally due to which power ic started getting heated. I replaced the sio chip with the same number but now laptop is no power no charging, not sure if sio needs internal ec rom reprogramming. Someone in above replies mentioned that this Lenovo Ite SIO doesn't need programming. Please suggest
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              It does not need programming, it'll program itself at first boot. Most probably you bought rebranded/fake chip, or pch is faulty as well (rare case but it's possible too).
                              Become a Badcaps supporter
                              Thanks to all supporters.​
                              • forespec
                                • Nov 2012
                                • 14
                                • India
                                In my case I accidentally shorted adapter I'd pin with 20v. Which shorted sio internally due to which power ic started getting heated. I replaced the sio chip with the same number but now laptop is no power no charging, not sure if sio needs internal ec rom reprogramming. Someone in above replies mentioned that this Lenovo Ite SIO doesn't need programming. Please suggest. Edit: thanks for reply. If PCH is faulty then atleast red led on DC jack should be on as soon as the adapter is connected and charging circuit should work. Thanks
                                • forespec
                                  • Nov 2012
                                  • 14
                                  • India
                                  Eventually it worked without any issues. Note: This SIO doesn't need programming. I think all Lenovo ITE SIOs don't need programming. It didn't work after replacing SIO because the power ic was faulty as well. I was confused because power ic was making 3v3 and 5v alw, 3.3 was present at power button, but I was not sure if this SIO requires programming. In my country SIO cost is around 16 us$. By the way does anyone know if SIO MEC 1515 NB programmable or not. Thanks in advance
                                  • phamduy221
                                    • Jan 2021
                                    • 54
                                    • vietnam
                                    MEC 1515 does not need programming note when replacing you need to load the original bios
                                    • nik0
                                      • Jul 2023
                                      • Ukraine
                                      Hello. write what board, I'll try to drain the backup from the working board
                                      • tomodachi
                                        • Apr 2012
                                        • 612
                                        • Turkey
                                        Hi
                                        Same model and same issue here.
                                        My question is have anyone had any success replacing IT8226-192 one with IT8226-128 version and get it to work on Y540 model ?
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
                                        • derradji89
                                          Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                          by derradji89
                                          Hi everyone 🤗
                                          I have a Lenovo MIX 320-10lCR computer.**
                                          1. **Operating System**: Windows 10 ** Education** 64-bit.
                                          2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                          3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                          4. **BIOS Chip Reflashing**: Currently,...
                                          04-19-2025, 03:04 PM
