Extract bios password from EliteBook 840 G8 Bios dump, possible?
Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
Thanks in advance
Model: AX201NGWLast edited by SMDFlea; 03-26-2023, 01:11 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
see the donate button below, at the bottom of the page, or
>>>>> click on this link to donate via PayPal. <<<<<
Doctrina est fructus dulcis, radicis amaraeComment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Here are your Unlocked files. program both chips together, in the first boot go to bios menu and disable security options (Default).----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Here are you Unlocked file, program the both chip together.
In the first boot go to bios menu and disable security options (Default).
Your bottom chip was (1KB) (200h) longer, it has the write size now.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
thank you very much, I will record here and testComment
In the first boot go to bios menu and disable security options (Default).----------------------------------------------------------------------------------------------------------------------------------------------------------------------
thanks alot brother its work perfectComment
Try...Attached FilesComment
Re: HP Elitebook 850 G8 bios locked
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
Channel: BIOS Requests ONLY!
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
- Loading...
