Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • hoaca388
    Badcaps
    • Jan 2022
    • 11475
    • Viet Nam
    #841
    Originally posted by asbachuk
    hp elitebook 865 G10
    S/N 5CG4155J3W
    SKU:8Z5H4EC #ABU
    BIOS PASSWORD RESET REQUIRED PLEASE
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • Deba Modok
      • Aug 2023
      • 6
      • Bangladesh
      #842
      Originally posted by Blaze Tech
      try
      Thank you brother, it's work fine
      • Buzzfuzz2k
        Bios password removal on a Unowhy dump
        by Buzzfuzz2k
        Hi Everyone,
        I'm facing a problem with a locked bios with a password and i can't find how to remove it...
        The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
        the Computer is a Unowhy small pc
        N° UYM6524702229
        After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
        My first attempt was to get the bios dump from windows...
        11-13-2023, 07:37 AM
      • traxformania
        TONGFANG "GM7TG7P" Bios Password Problem?
        by traxformania
        I tried :
        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
        11-15-2023, 07:32 AM
      • Nopslide
        by Nopslide
        04-01-2024, 04:27 PM
      • outsider
        Panasonic FZ-G1 MK5 - BIOS password returning
        by outsider
        Hello
        I removed the BIOS password thanks to the help of one of the friends of this forum.
        https://www.badcaps.net/forum/troubl...61#post3637661
        The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
        06-17-2025, 12:51 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
