Lenovo e460 bios problem
  • bilen
    • Aug 2014
    • 632
    • istanbul
    motherboard code : NM-A551
    device turns on and works but
    Invalid RFID configuration information area;
    Invalid RFID serialization information area;
    Machine type and serial number are invalid
    Machine UUID invalid.
    gives an error message. how can i fix this?
    NOTE: I wrote other bios in the forum
    .same result
  • peste
    • 12530
    • ROMANIA
    Re: Lenovo e460 bios problem
    .same result
    DMI information is missing from the bios
    • bilen
      • Aug 2014
      • 632
      • istanbul
      what should I do ?
      • bilen
        • Aug 2014
        • 632
        • istanbul
        Anyone know the solution for this?
          • 20596
          Do you have the original bios backup.
          • bilen
            • Aug 2014
            • 632
            • istanbul
            unfortunately. this is how it arrived
              • 20596
              You will have to add the DMI info . Try this - https://github.com/ASparkOfFire/lenovo-u1-tool .If it doesn`t work look for LVAR64 (lenovo variable tool) or the lenovo hardware maintenance diskette
              • bilen
                • Aug 2014
                • 632
                • istanbul
                0189 error persists:
                It was fixed after the procedure you said :
                ''Invalid RFID serialization information area;
                Machine type and serial number are invalid''
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • grimacelord
                  by grimacelord
                  Hello there.
                  History:
                  03-15-2023, 03:29 PM
                • mximiliandz
                  help bios lenovo ideapad s145-14iil type 81w6
                  by mximiliandz
                  Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                  06-20-2025, 06:50 AM
                • 1g0r
                  Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                  by 1g0r
                  First, the data in brief:
                  Manufacturer: Lenovo
                  Model: ThinkPad L15 G3 21C3-0016GE
                  motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                  IC Bios 1: MX77L25650F
                  IC Bios 2​: MX25L25673G
                  EC Chip: NPCX997KAABX
                  So far I've been a silent reader, but now I need your help
                  I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                  I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                  The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                  01-18-2025, 02:39 AM
                • abhorsen
                  Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                  by abhorsen
                  Hey guys,
                  Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                  Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                  Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                  07-06-2023, 10:22 AM
