HP Elitebook 850 G6 BIOS UNLOCK
Please follow this format
issue:
Model:
Serial Number:
Motherboard Code:Comment
Please unlock my Elitebook 850 G6.Thank You
laptop details
HP Elitebook 850 G6
ProdiD - 4YD60AV
SN# 5CG0130PM6
here
hp 850 g6 bios pw
6050a3022501-mb-a01[a1]
28K9430D4Q
any can give unlock file plsAttached FilesComment
HereAttached FilesComment
Serial : 2TK9430D4QAttached Files↵
https://www.badcaps.net/donateComment
hello!) please unlock my bios 850 g6 my s\n: 5CG944406BAttached FilesComment
hereAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
by mkdjDear all,
I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...-
Channel: BIOS Requests ONLY!
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
by druxHi,
I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
These models have AMI/Aptio BIOS.
Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...-
11-03-2024, 01:18 AM -
- Loading...
