Alienware M14X R1 bios needed
  • salawayon
    • Nov 2012
    • 578
    • philippines
    info:
    PALBO LA-6801P
    REV: 1.0 (A00)
    2011-01-24
    No display problem on this one.. U604 (1mb bios chip) was empty, i tried to read it 3x but upon checking it's all FFFF... i attached my backup except for the content of U604. thanks.
  • klinik
    • Nov 2018
    • indonesia
    Re: Alienware M14X R1 bios needed
    this bios its working
    • drux
      Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
      by drux
      I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
      Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
      These models have AMI/Aptio BIOS.
      Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
      11-03-2024, 01:18 AM
    • santoslao
      Alienware m16 R2 bios Dump needed
      by santoslao
      I received an Alienware m16 R2 computer with the cursed "Legacy manageability interface" enabled.
      I tried to downgrade the version to the oldest possible one, as I mentioned in another topic > Inspiron 15 3530 bios
      However, the machine wouldn't turn on! So I reverted to the original version 1.15.0, which I had already backed up.
      I decided to try reverting the versions manually, using the .rcv file from the Dell website, and I only managed to do it with version 1.14.0.
      The next day I thought about flashing a clean ME version of version...
      11-23-2025, 12:18 PM
    • tlindi
      Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
      by tlindi
      Sublect line continuation: ... Jaguar IDS PC aka Panasonic
      Ack
      Ack
      01-30-2025, 04:26 AM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • kamkam336
      Alienware Aurora R8/9 Bios .bin file needed
      by kamkam336
      I got a new mobo from Aliexpress for my Aurora r9 and everything was working fine until i did a bios update. It did not work and now i get 3x, 7x, 3x, 6x blinking code. Dell says that is a corrupt bios. So i have the ch341 and software required, i just don't have the bios.bin file.
      Since the board is from Aliexpress it doesn't have a service tag, I have a copy of the .exe bios and a copy of my corrupted bios attached. Hopefully this is enough, if anyone is able to help me and requires any more information please let me know.
      Thanks ...
      08-19-2024, 06:59 PM
