HP - 15-ax009np bios has wrong keyboard layout
  • Jekkaman
    • Nov 2021
    • 5
    • Portugal
    Recently i tried to update the bios on my laptop to the latest version, F.56 Rev.A.
    For some reason, the bios seemed to flash well, but after rebooting, the laptop turned on but the screen remained black.
    Since this was a BIOS issue, i searched for a BIOS dump and flashed it so i could have my laptop working again.
    It worked successfully but it seems that the bios i flashed is from another variant 15-ax016tx which does have another keyboard layout.
    EDIT: This is exactly what i'm experiencing: https://h30434.www3.hp.com/t5/Notebo...t/td-p/6797451
    Before flashing the new BIOS i made a backup just in case.
    Is there anyway i could dump the current bios and copy the information from the backup and have the laptop with all the correct information ?
    Can anyone instruct me how to do it ?
    My Laptop is this variant:https://support.hp.com/pt-pt/drivers...model/13222200
    The flash bios is this variant:https://support.hp.com/pt-pt/drivers...34?sku=X1G86PA
    If there's any info you need just let me know.
    Thank you very much.
  • peste
    • Dec 2016
    • 12569
    • ROMANIA
    Re: HP - 15-ax009np bios has wrong keyboard layout
    post the copy of the original bios of the laptop.
    • Jekkaman
      • Nov 2021
      • 5
      • Portugal
      Here it is.
      • lapfix
        • Mar 2020
        • 2702
        • my workshop
        Here it is.
        This dump have no DMI ?
        • Jekkaman
          • Nov 2021
          • 5
          • Portugal
          I dumped that bios with the programmer before flashing a new one. It's all i've got.
          • lapfix
            • Mar 2020
            • 2702
            • my workshop
            Try
              • 20619
              it sure does
              D 6AC000 - 6AE0FF
              W 278000 - 27803F
              • Jekkaman
                • Nov 2021
                • 5
                • Portugal
                Try
                After flashing this one the screen is blank and the caps lock keeps blinking.
                • lapfix
                  • Mar 2020
                  • 2702
                  • my workshop
                  Originally posted by SMDFlea
                  it sure does
                  D 6AC000 - 6AE0FF
                  W 278000 - 27803F
                  Sorry SMDFLEA ..i use a soft that can't see the dmi in this dumb!!
                  • NotEnough
                    Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                    by NotEnough
                    I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                    What I've Tried So Far:
                    • Reseated the cables.
                    • Reinstalled AWCC and AlienFX services.
                    • Attempted BIOS downgrade but no improvement.
                    • Inspected ribbon cables for damage.
                    • Explored the possibility of BIOS or
                    10-19-2024, 01:34 AM
                  • BMCappelletti
                    Asus Chromebox CN62 - wrong chip put on BIOS reader
                    by BMCappelletti
                    Long story short:
                    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                    - gave the computer to his son a couple years later
                    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                    (seems like the story was not that short)
                    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                    01-08-2025, 07:27 PM
                  • Loli Popu
                    DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                    by Loli Popu
                    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                    12-13-2024, 03:28 AM
                  • BlueNitesFire
                    I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                    by BlueNitesFire
                    So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                    03-08-2025, 03:49 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
