i need nb8517 mb v2
  • tribalcore20
    • Jun 2020
    • 66
    • Philippines
    i need nb8517 mb v2
    hello. can some one send me a working bios bin for this
    board NB8517 mb v2 board
    Acer n19h2 model
  • lapfix
    • Mar 2020
    • 2765
    • my workshop
    Re: i need nb8517 mb v2
    post your old dump
    • tribalcore20
      • Jun 2020
      • 66
      • Philippines
      wait sir i will copy
      • tribalcore20
        • Jun 2020
        • 66
        • Philippines
        here is the file
        • lapfix
          • Mar 2020
          • 2765
          • my workshop
          Originally posted by tribalcore20
          here is the file
          Try
          • tribalcore20
            • Jun 2020
            • 66
            • Philippines
            ill try. thanks
            • tribalcore20
              • Jun 2020
              • 66
              • Philippines
              still no power. maybe its not bios problem.
              • lapfix
                • Mar 2020
                • 2765
                • my workshop
                your serial number or SNID please
                • tribalcore20
                  • Jun 2020
                  • 66
                  • Philippines
                  Here sir
                  • lapfix
                    • Mar 2020
                    • 2765
                    • my workshop
                    No , you will find it at a ticket at the back of your lap with models etc
                    • tribalcore20
                      • Jun 2020
                      • 66
                      • Philippines
                      model
                      a514-52k-NL
                      s/n nxhkwsp003933002e54s00
                      snid 933000741428
                      • zathan
                        • Mar 2021
                        • 7
                        • Philippines
                        hi need help fix my bios
                        hi need help for bios Acer A514-52kg-34h4 / nb8517_mb_v2
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12396
                          Aspire A514-52KG
                          • snar
                            • Feb 2018
                            • 74
                            • philippines
                            Hi everyone, can you help me fix my bios. the problem is delayed display.
                            motherboard model NB8517-MB-V2
                            sn: NXHL4SP00395102E9B2N00
                            Thanks in advance. i attached my old bios.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12396
                              • snar
                                • Feb 2018
                                • 74
                                • philippines
                                Originally posted by hoaca388
                                thank you sir. i just try the bios of number #13 but unfortunately the laptop has no display. but if i flash my original bios back the laptop will display but it took 42 seconds. can you fix my original bios sir. thank you in advanced.
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                • Destroyer-Br
                                  [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                  by Destroyer-Br
                                  I'm working on an Acer Nitro 5 unit with the following specs:
                                  • Motherboard: LA-J871P Rev: 1B
                                  • Model: Acer AN515-55-59MT
                                  • S/N: NHQ7JAL00403906A973400
                                  • SNID: 03902728734
                                  Initial Issue
                                  The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                  After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                  04-17-2025, 08:18 PM
                                • makinen
                                  Acer SwiftX 14 SFX14-41G gh4fz LA-L202P Rev 1.0 board view file needed
                                  by makinen
                                  MB: Acer GH4FZ LA-L202P Rev 1.0
                                  Model no: Acer Swift SFX14-41G
                                  My laptop has random shutdown during use no matter high or low loading since a year ago, but still can be restarted. One day, it got very hot at the bottom near the power chip (PUB1) during use, and finally shutdown when in use and cannot switch on again (like dead), so I suppose there is no major failures and power issue should be fixable.
                                  There is no visual burnt or component damage, I tracked the power rail that the power seems blocked at charger chip (PUB1), measured some resistors...
                                  11-10-2025, 03:41 AM
                                • Roman555
                                  [Offer] Acer IPIMB-AR (w/o on-board gfx) of Acer Predator G5920 fullflash BIOS
                                  by Roman555
                                  I'd like to offer an Acer IPIMB-AR Rev: 1.02A fullflash BIOS (cleaned ME region). The model is for Acer Predator G5920.
                                  It is a model that is based on Intel Z77 PCH and doesn't have on-board graphics and video connectors.
                                  I suppose it doesn't have any restriction about discrete graphics cards (I mean they don't have to be in a whitelist).
                                  Please don't mistake this mainboard with a similar model with on-board graphics and based on Intel B75 PCH.
                                  Jumper FLASH_OVERRIDE
                                  default position: 1-2 - BIOS area protected
                                  position 2-3 allows to dump BIOS or write
                                  06-26-2025, 05:15 AM
