Lenovo Yoga 2 13 Bios Rom <> EC
  • webwicht
    • Oct 2021
    • 8
    On a Lenovo Yoga 2 13 an older version of the Bios and EC firmware was installed.
    When reading out the Bios Rom with a bad CH341-HW-Flasher I damaged the Rom:
    Lenovo was brick dead.
    Now I found a backup copy of the Bios-Rom 1.17 for this computer on my hard drive,
    which I created times ago with the Insyde H2OFFT-tool. (I have to say that I downgraded Bios in the hope that it would accept another wifi card)
    After installing a new bios Rom which I flashed with the backup I could switch on the laptop, keyboard lights turn on and fan briefly spins up but screen stays dark and device does not boot further. However the laptop can be turned off what was not the case with the dead rom.
    When turning on, short traffic at the Bios-Rom pins (CS,SO,SI,CK) can be observed with a cheap oscilloscope.
    My assumption (and hope) is that Bios-version and EC-version must match. Is this correct? Unfortunately I do not have a backup of the EC nor of the older Bios firmware.
    Could I get an older version of the EC firmware?
    Is the EC firmware also customized?
    How could I flash it?
    Or how could I customize an older version of the vanilla rom from Lenovo page with the data from the backup version?
    Maybe my assumption is completely wrong and there is another fancy security feature (UEFI) that prevents from booting...
    • 22289
    Re: Lenovo Yoga 2 13 Bios Rom &lt;&gt; EC
    Post your backup here in a zip or rar .
    • webwicht
      • Oct 2021
      • 8
      Attached find the Backup. It says:
      1V$96CN31WW(V1.17)
      • webwicht
        • Oct 2021
        • 8
        EC-Rom data seems to be not customized and programming of Embedded controller KB9012 seems to be possible with moderate means as explained here:
        http://dangerousprototypes.com/docs/...ith_Bus_Pirate
        • webwicht
          • Oct 2021
          • 8
          Meanwhile I am able to read and write Embedded Controller KB9012.
          I flashed the EC.BIN for the 1.17 that I found in the forum and flashed it.
          However the laptop still does not boot.
          But I realized that the Fan moves now, the power LED blinks from time to time and the Laptop beeps when starting.
          I am not sure if my assumption is correct that EC-Rom needs not to be customized.
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • maeson
            BIOS Request - Lenovo Yoga L13 Gen3 (AMD)
            by maeson
            Hi dear Badcaps-Community,
            Somehow an auto update, which I triggered before I left my laptop unattended, bricked my BIOS.
            I was able to extract the 2MB BIOS and 16MB BIOS which I will attend. (CH341B black with NeoProgrammer 2.2.0.10)
            The Device is a Lenovo Yoga L13 Gen3 and I was able to identify the following specifications:
            Lenovo Yoga L13 Gen 3 AMD:
            Lenovo Modell: Type 21BB
            Artikelnr.21BB006GGE
            Seriennummer: PW0A6207
            AMD Ryzen™ 5 PRO 5675U
            Memory 16 GB DDR4-3200MHz
            SSD: 512 GB SSD, M.2 2242, PCIe Gen4, TLC,...
            10-31-2025, 03:08 AM
          • DiddiAb
            BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
            by DiddiAb
            Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
            I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
            03-11-2023, 03:15 AM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • beogeek
            Lenovo Yoga Slim 7 14APU8 Bios Request
            by beogeek
            I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
            Attached is the bios dump in the state I received it...
            10-24-2024, 12:54 PM
