help me dell 7320-7420 PASS
Re: help me dell 7320-7420 PASS
Thank you for the file, Unfortunately while soldering to the board I shifted few components and laptop won't power on anymore even bios and components are soldered back.
I have got one more laptop with identical motherboard (Dell Latitude 7320). Could you pls unlock the dump file attached for me? I have a private repair shop and learning the stuff. What method you use to clear the pass? Are you able to find it inside the file? You are my saviour with both cleared bioses. Thank you again in advance.Last edited by SMDFlea; 04-10-2023, 10:54 AM.Comment
I have got one more laptop with identical motherboard (Dell Latitude 7320). Could you pls unlock the dump file attached for me? I have a private repair shop and learning the stuff. What method you use to clear the pass? Are you able to find it inside the file? You are my saviour with both cleared bioses. Thank you again in advance.Last edited by SMDFlea; 04-10-2023, 10:54 AM.↵
https://www.badcaps.net/donateComment
Thank you. I programmed the data to the chip and soldered back. Now I can't see any light on and measuring the bios chip pins voltage has changed to 1.8v instead 3.3 Does it needs to be activated somehow or I burned something out again? Thank you for help.Comment
What ? How can it change from 3.3 vol to 1.8 vol ? What's code name of chip ? Just to be sure on first boot you have to go into bios settings to disable all security options.Last edited by hoaca388; 07-17-2022, 08:26 AM.↵
The voltage changed on the 7420 motherboard as well. It looks like I burned something out but I just soldered the chip with hot gun.I am getting this values on bios chip (Winbond 25R2S6JVEN)
Pin 1 - 1.3V
Pin 2 - 1.9V
Pin 3 - 1.9V
Pni 4 - 0V
Pin 5 1.3V
Pin 6 - 1.9V
Pni 7 - 0V
Pin 8 - 0VComment
As far as I know pin number 8 must have 3.3 volts.↵
Post your problem here : https://www.badcaps.net/forum/forumdisplay.php?f=23↵
Re: Dell Latitude 7400 Bios Password
can you help me? I do not know exactly which chip to read and where to find it.
I read this one out but the file is only 1MB. Can this be correct?
I have a Latitude 7420 2-in-1 (Not the one in the photo. I got the picture from the internet. But mine looks exactly the same.)Last edited by SMDFlea; 04-10-2023, 10:54 AM.Comment
Hi to All friend's and expert teacher
need Dell latitude 7420 #9P0R7M-8FC8 bios unlock code...Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by madjid911Hi, i need bios DELL OPTIPLEX 5480 ALL-IN-ONE, or if anyone can unlock my password please.
I couldn't find a generic password...-
Please Remove Password of this Bios
Model : Dell XPS 13 9315
Motherboard : HDP 33 LA-L231P
Rev : 1.0 (A00)
Serial No : J49MHR3...-
Channel: BIOS Requests ONLY!
by H8CoreHello folks,
an acquaintance brought me a motherboard from a Dell Latitude 5520 with the mainboard 0g60m3...
Bios corrupt and admin password from his children, they are 7 and 9y old.
Today I wanted to desolder the chip with hot air in order to be able to read it out and possibly rewrite it.
It's not the first time I've done something like this, but Dell is new territory. can it be that dell sticks the bios chips on? I could not remove the chip (W25R256JVEN). is there a how to or information?
Thanks-
- Loading...
