help me dell 7320-7420 PASS
  • dgs3342
    • May 2017
    • 36
    • Italia
    #61
    Re: help me dell 7320-7420 PASS
    Originally posted by Vesko356
    It's under warranty. Contact Dell Support for assistance with proof of purchase.
    Actually I've managed to modify the bios to clean the lock but I don't know exactly how. Very strange.
    • Ferimonka
      • Nov 2019
      • 40
      #62
      Thank you for the file, Unfortunately while soldering to the board I shifted few components and laptop won't power on anymore even bios and components are soldered back.
      I have got one more laptop with identical motherboard (Dell Latitude 7320). Could you pls unlock the dump file attached for me? I have a private repair shop and learning the stuff. What method you use to clear the pass? Are you able to find it inside the file? You are my saviour with both cleared bioses. Thank you again in advance.
      • hoaca388
        • Jan 2022
        • 11131
        • Viet Nam
        #63
        Dell Latitude 7320
        Become a Badcaps supporter
        Thanks to all supporters.
        • Ferimonka
          • Nov 2019
          • 40
          #64
          Thank you. I programmed the data to the chip and soldered back. Now I can't see any light on and measuring the bios chip pins voltage has changed to 1.8v instead 3.3 Does it needs to be activated somehow or I burned something out again? Thank you for help.
          • hoaca388
            • Jan 2022
            • 11131
            • Viet Nam
            #65
            What ? How can it change from 3.3 vol to 1.8 vol ? What's code name of chip ? Just to be sure on first boot you have to go into bios settings to disable all security options.
            • Ferimonka
              • Nov 2019
              • 40
              #66
              The voltage changed on the 7420 motherboard as well. It looks like I burned something out but I just soldered the chip with hot gun.I am getting this values on bios chip (Winbond 25R2S6JVEN)
              Pin 1 - 1.3V
              Pin 2 - 1.9V
              Pin 3 - 1.9V
              Pni 4 - 0V
              Pin 5 1.3V
              Pin 6 - 1.9V
              Pni 7 - 0V
              Pin 8 - 0V
              • hoaca388
                • Jan 2022
                • 11131
                • Viet Nam
                #67
                As far as I know pin number 8 must have 3.3 volts.
                • Ferimonka
                  • Nov 2019
                  • 40
                  #68
                  I found out the voltage is ok when chip is de-soldered. Once soldered back the voltage drops down as mentioned. Any idea why this behavior?
                  • hoaca388
                    • Jan 2022
                    • 11131
                    • Viet Nam
                    #69
                    Post your problem here : https://www.badcaps.net/forum/forumdisplay.php?f=23
                    • justice171
                      • Feb 2018
                      • 101
                      • South Africa
                      #70
                      Try & leave feedback:
                      Good day, can you assist with the BIOS password for suffix 8FC8
                      Dell Latitude 7420 Board number GDC31 LA-K371P
                      BIOS BIN Below
                      • hoaca388
                        • Jan 2022
                        • 11131
                        • Viet Nam
                        #71
                        BIOS BIN Below
                        [ATTACH]270226[/ATTACH]
                        Unlocked
                        • justice171
                          • Feb 2018
                          • 101
                          • South Africa
                          #72
                          Originally posted by hoaca388
                          Unlocked
                          Wow, it worked now I can change settings on the BIOS dude you are a genius I wish I knew how to do it so that I can help others on the badcaps forum.
                          • Kaiser87
                            • Aug 2022
                            • it
                            #73
                            Re: Dell Latitude 7400 Bios Password
                            can you help me? I do not know exactly which chip to read and where to find it.
                            I read this one out but the file is only 1MB. Can this be correct?
                            I have a Latitude 7420 2-in-1 (Not the one in the photo. I got the picture from the internet. But mine looks exactly the same.)
                            • Kaiser87
                              • Aug 2022
                              • it
                              #74
                              It is a winbond 25Q80DVSIG
                              • hoaca388
                                • Jan 2022
                                • 11131
                                • Viet Nam
                                #75
                                Name of chips ?
                                • Kaiser87
                                  • Aug 2022
                                  • it
                                  #76
                                  Name of chips ?
                                  upper one: winbond 25R256JVEN
                                  lowwer one: XMCC QH128AHIG
                                  • hoaca388
                                    • Jan 2022
                                    • 11131
                                    • Viet Nam
                                    #77
                                    upper one: winbond 25R256JVEN = 32MB Data
                                    lowwer one: XMCC QH128AHIG = 16 MB data.
                                    Read Winbond chip.
                                    • alikhoso0786
                                      • Dec 2021
                                      • Pakistan
                                      #78
                                      Hi to All friend's and expert teacher
                                      need Dell latitude 7420 #9P0R7M-8FC8 bios unlock code...
                                      • imranromi
                                        • Jan 2015
                                        • 1288
                                        • Pakistan
                                        #79
                                        You need to open laptop find bios chip read and post here.
                                        • farouk_1994
                                          • Mar 2021
                                          • 385
                                          • algeria
                                          #80
                                          i have LOCKED bios dell 7420 HELP
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • madjid911
                                            Bios dell optiplex 5480 ALL-IN-ONE remove pass
                                            by madjid911
                                            Hi, i need bios DELL OPTIPLEX 5480 ALL-IN-ONE, or if anyone can unlock my password please.
                                            I couldn't find a generic password...
                                            09-23-2023, 11:52 AM
                                          • H8Core
                                            with hot air cant remove bios chip dell 0g60m3
                                            by H8Core
                                            Hello folks,
                                            an acquaintance brought me a motherboard from a Dell Latitude 5520 with the mainboard 0g60m3...
                                            Bios corrupt and admin password from his children, they are 7 and 9y old.
                                            Today I wanted to desolder the chip with hot air in order to be able to read it out and possibly rewrite it.
                                            It's not the first time I've done something like this, but Dell is new territory. can it be that dell sticks the bios chips on? I could not remove the chip (W25R256JVEN). is there a how to or information?
                                            04-20-2023, 04:47 AM
                                          • kingaarbi
                                            dell latitude e7450 need remove pass
                                            by kingaarbi
                                            dell latitude e7450
                                            S/n: 51QDZ52...
                                            11-10-2021, 05:51 AM
                                          • roli1980
                                            DELL 3520 - Help Repair - Remove Enterprise
                                            by roli1980
                                            hi , i have a dell 3520 cyborg - 15 11th
                                            while there is no bios lock , there seems to be a enterprise attachment
                                            when i try to install windows 11 it just wont go past the account part , while i know i can bypass , i would rather change key or bios
                                            i have attached the OG Bios could anyone give me a clean one ?
                                            regards...
                                            08-08-2024, 09:46 AM
