hp elitebook 745 g6 amd bios unlock
  • gnoozle
    • May 2018
    • 54
    • gnoojpoh
    #41
    hp elitebook 745 g6 locked
    i need to unlock hp elitebook 745 g6 locked amd . hope you help me
    • hardware1
      • Sep 2021
      • 2897
      • N/A
      #42
      Re: hp elitebook 745 g6 locked
      Here's your Unlocked file, in the first boot go to bios menu and disable security options (Default). If the password still present, upload the other chip (EC) it could be 16MB.
      all donations are welcome,
      • gnoozle
        • May 2018
        • 54
        • gnoojpoh
        #43
        Thanks for helping. Will try in few hours
        • gnoozle
          • May 2018
          • 54
          • gnoojpoh
          #44
          after trying your dump pc doesn't power up.. and fan run at high speed ..here's my chips u366 and u365 new updoad thanks a gain . this pc make me crazy
          • hardware1
            • Sep 2021
            • 2897
            • N/A
            #45
            Here.
            • bioteux
              • May 2023
              • 4
              • germany
              #46
              Re: hp elitebook 745 g6 amd bios unlock
              Good afternoon. I had the same bios password problem on hp elitebook 745 g6. If I correctly filled in for a successful password reset, you need dumps from the U365 and U366 chips?
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #47
                Well it depends on the specific case, but in the general (administrator password has been set only) the dump from the U366 is needed.
                Become a Badcaps supporter
                Thanks to all supporters.​
                • bioteux
                  • May 2023
                  • 4
                  • germany
                  #48
                  Yes. Requires an administrator password when entering the BIOS and boot menu.
                  Tomorrow I will get a dump from u366. Do you prefer *.bin or *.hex ?
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #49
                    I prefer a good verified dump of the chip, file extension doesn't matter.
                      • 20318
                      The hex file will be larger in size,If the *.hex is opened with HxD it looks like a bunch of numbers.If the *.hex is imported though it looks like what we would normally expect to see.
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #51
                        And vice versa - normal binary dump file opened with HxD can be exported as a *.hex, but yes it's more than double in size.
                        • bioteux
                          • May 2023
                          • 4
                          • germany
                          #52
                          Here is a dump from U366. Hopefully good.
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #53
                            Use RCUnlocker to do it yourself.
                            https://www.badcaps.net/forum/showthread.php?t=98539
                            • bioteux
                              • May 2023
                              • 4
                              • germany
                              #54
                              Didn't work
                              • hardware1
                                • Sep 2021
                                • 2897
                                • N/A
                                #55
                                Didn't work
                                You are facing this error because your BIOS file has a larger size than the normal file, delete the extra (200h) length in the end of your file and try again.
                                • MAZMAZ23
                                  • Jan 2023
                                  • 31
                                  • ALGER
                                  #56
                                    • 20318
                                    Read post #53
                                    • MAZMAZ23
                                      • Jan 2023
                                      • 31
                                      • ALGER
                                      #58
                                      Didn't work
                                      • MAZMAZ23
                                        • Jan 2023
                                        • 31
                                        • ALGER
                                        #59
                                        Help me
                                          • 20318
                                          Help me
                                          Post backup from other bios chip.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • clrscr
                                            Need unlock bios hp elitebook 835 G11
                                            by clrscr
                                            please help me unlock bios password hp elitebook 835 G11
                                            S/N: 5CG50434RD
                                            thanks!...
                                            06-04-2025, 09:38 PM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
                                          • Bharath Ram
                                            HP Elitebook MT45 Bios Unlock
                                            by Bharath Ram
                                            Hi
                                            Can someone please unlock the attached bios file
                                            Laptop: HP MT45
                                            Chip: W25Q256JV
                                            Thanks...
                                            06-21-2025, 09:09 PM
