hp elitebook 745 g6 amd bios unlock
  • hardiyantowa
    • Sep 2023
    • Indonesia
    #61
    Re: hp elitebook 745 g6 amd bios unlock
    hi can i use another bios file to my chip? because i dont have a backup for my bios, it's bricked
    • hoaca388
      Badcaps
      • Jan 2022
      • 12269
      #62
      HP EliteBook 745 G6 Base Model Notebook PC
      • hardiyantowa
        • Sep 2023
        • Indonesia
        #63
        Thanks sir 4 ur help, gotta try this ASAP.
        • dbtx
          PEBKAC
          • Nov 2015
          • 7
          I removed and tried RCUnlocker on the contents of what I think is U366, actually a W25Q128JV sitting snugly between the M.2 and DIMM2 slots, and I'm still locked out of setup.
          In case it helps, here's what I did, essentially:
          Code:
          # flashrom --programmer buspirate_spi:dev=/dev/ttyUSB0 -c "W25Q128.V" -r spidump.bin
          flashrom v1.3.0 on Linux 5.10.160-gentoo (x86_64)
          flashrom is free software, get the source code at https://flashrom.org
          Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
          Found Winbond flash chip "W25Q128.V" (16384 kB, SPI) on buspirate_spi.
          This flash part has status UNTESTED for operations: WP
          The test status of this chip may have been updated in the latest development
          version of flashrom. If you are running the latest development version,
          please email a report to flashrom@flashrom.org if any of the above operations
          work correctly for you with this flash chip. Please include the flashrom log
          file for all operations you tested (see the man page for details), and mention
          which mainboard or programmer you tested in the subject line.
          Thanks for your help!
          Reading flash... done.
          # cp spidump.bin /path/to/usb/drive/hp_eb_745G6_U366_orig.bin
          Then I dropped the file onto RCUnlocker.exe in an old Windows 7 laptop and copied it back in...
          Code:
          # md5sum hp_eb_745G6_U366_*
          12ddd7780641c31293df20f614f963bd hp_eb_745G6_U366_modded_unlocked.bin
          8b534a83ec1683808cb461f0a4c2c6f0 hp_eb_745G6_U366_orig.bin
          # flashrom --programmer buspirate_spi:dev=/dev/ttyUSB0 -c "W25Q128.V" -w hp_eb_745G6_U366_modded_unlocked.bin
          Reading old flash chip contents... done.
          Erasing and writing flash chip... Erase/write done.
          Verifying flash... VERIFIED.
          Then I replaced the chip and reconnected the 2 batteries. Everything still works fine, but it didn't seem to act any differently. So I listed the actual changes made by RCUnlocker, which appear to be mostly sets of 0xff bytes swapped with sets of 0x00 bytes and vice versa, in the attached file:
          Code:
          # hexdump hp_eb_745G6_U366_modded_unlocked.bin -vC > unlocked.hxdmp
          # hexdump hp_eb_745G6_U366_orig.bin -vC > original.hxdmp
          # diff -u original.hxdmp unlocked.hxdmp | unix2dos > /tmp/hexdump_diff.txt
          I couldn't easily find any RCUnlocker other than 1.0 in the first post of that thread, so that's what I used. Any light anyone can shed will be appreciated. Thanks in advance!
          • hoaca388
            Badcaps
            • Jan 2022
            • 12269
            #65
            Exactly. The only thing left is to watch your chip burning process.
            • dbtx
              PEBKAC
              • Nov 2015
              • 7
              I also tried HPUnlocker and it merely changed the earlier part identically, skipping those many groups of 0xff. Maybe it means this should be enough... I will try to flash again.
              Code:
               00027260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
               00027270 12 00 00 00 c0 11 00 00 ff 87 66 f6 f3 8c 19 4a |..........f....J|
               00027280 b4 ac f5 f0 b7 8e 4d 18 55 00 73 00 65 00 72 00 |......M.U.s.e.r.|
              -00027290 43 00 72 00 65 00 64 00 00 00 02 00 00 00 00 00 |C.r.e.d.........|
              -000272a0 00 00 02 00 00 00 00 00 00 00 41 00 64 00 6d 00 |..........A.d.m.|
              -000272b0 69 00 6e 00 50 00 57 00 00 00 00 00 00 00 00 00 |i.n.P.W.........|
              +00027290 43 00 72 00 65 00 64 00 00 00 00 00 00 00 00 00 |C.r.e.d.........|
              +000272a0 00 00 ff ff ff ff 00 00 00 00 00 00 00 00 00 00 |................|
              +000272b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
               000272c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
              -000272d0 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 |................|
              +000272d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
               000272e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
               000272f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
               00027300 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
              • dbtx
                PEBKAC
                • Nov 2015
                • 7
                TL;DR: It was U365. Take out the mobo and do it to U366 found in almost the same place under/opposite the SSD, not beside the SSD.
                The silkscreen showed what appeared to be "U366" in that area, but after I took a decent photo and zoomed in, it was U368 ever-so-slightly misprinted by part of the 8 landing on a via. I briefly thought the IC definitely should be U365 because "U366" (U368) was farther away, and CN365 is right on top of it, as if a socket would go on that SOIC-8-like footprint that surrounds the WSON pads, and it had the same number as if for holding the same IC just in a different package. I compared it to this photo and didn't see anything that should match (the Parade chip). But I had to make sure, the hard way. The real problem is I didn't yet realize (or admit) I absolutely did need to remove the board, even though I had already seen another success and this note. Well, I also didn't think some Elitebooks had such similar innards.
                My bad.
                So I restored the backup of U365 after I (actually, finally) ran RCUnlocker on the image of U366. And it didn't tell me anything except 'ok, finished' unlike the first time when it wrote out quite a bit of information about the U365 image I gave it, which was weird.
                Well, it's sorted now. Thanks, everyone!
                • daasco
                  • Dec 2017
                  • 27
                  • Lebanon
                  #68
                  HELLO IF YOU CAN HELP ME WITH TO FIX
                  there is problem with hp endpoint security controller
                  6050A3044201-MB-A01
                  HP 745 G6
                  BEST REGARDS
                • farouk_1994
                  • Mar 2021
                  • 396
                  • algeria
                  #69
                  Flash only the U366 chip Try it than replay after you turn it on go to security and reset to default.
                    SMDFlea commented
                    Editing a comment
                    Please do not help members who do not post the serial numbers !
                • daasco
                  • Dec 2017
                  • 27
                  • Lebanon
                  #70
                  6050A3044201-MB-A01
                  HP 745 G6
                  BEST REGARDS
                  SAME PROBLEM
                  • CammyTier1
                    Tier 1 Assets
                    • May 2022
                    • 43
                    [QUOTE=daasco;n3166128
                    ​[/QUOTE]
                    Go to bios and reset security options
                    • daasco
                      • Dec 2017
                      • 27
                      • Lebanon
                      #72
                      ALREADY DID
                      SAME PROBLEM
                    • Gürkan Yesilkaya
                      • Jan 2024
                      • Deutschland
                      #73
                      Hello have a buy a hp Elitebook 745 G6 amd ryzen pro 3500. Have a problem with him. First problem was admin Password set. Solderded U366 bioschip (mx25l12873f) and flashed new bios. And solded bioschip on platine and took ac on and no boot only caps only white and ac symbol flash white and yellow. My fail i have not Backup!
                      my Questionen is can i onther bios.bin flash ? Hp homepage biosfirmeware cannot too big!
                      Then a buy i have no ram or orginal windows nvme !
                      Serial Number. 5CG0105KPR
                      SKU Number. 7YD45UC#ABD
                      R74 Ver.01.19.00 01/14/2022
                      System Board ID 8584
                        Vesko356 commented
                        Editing a comment
                        You MUST:
                        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                        • Provide a BIOS/EC dump if possible
                        • Attach files directly to your post instead of linking to external websites
                    • shenmeur
                      • Sep 2016
                      • 38
                      • algeria
                      #74
                      help please removing password hp elitebook 745 g6
                      prodid 5vu37av
                      sn:5cg00429c6
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12269
                        #75
                        prodid 5vu37av
                        sn:5cg00429c6
                        Use RC unlocker for U366.
                        • Tves
                          • 6
                          • RF
                          #76
                          Hi! Laptop (EliteBook 745 G6) no unolck(( DUMP is attached. Thanks in advance!!!
                          Model: HP EliteBook 745 G6
                          SN:5CG0138JL9
                          BCT: PJBVR00WBDJ0ZY
                          SPI: WINBOND 25Q128JV​
                          • peste
                            peste commented
                            Editing a comment
                            post merged..
                        • peste
                          • 13430
                          • ROMANIA
                          #77
                          post the S/N, the motherboard model, etc.
                          • vignesharivuslm
                            • Nov 2014
                            • 33
                            • India
                            #78
                            Official file extract 16mb only
                            • didouche1200
                              • Oct 2016
                              • 367
                              • 82679911441
                              #79
                              hi
                              i have an elitebook 745 g6 - 6050A3044201 - MB -A01(A1) SN: 5CG0250KKT
                              it does not turn on the display then it reboots
                              i have the three chip files
                              thanks​
                              • matis267
                                • Apr 2025
                                • India
                                #80
                                I need help unlocking the BIOS password on my HP EliteBook 745 G6.
                                HP is no longer providing SMC.bin files, and I cannot access BIOS settings or install Windows.
                                Here are my system details:
                                - Model: HP EliteBook 745 G6
                                - Serial Number: 5CGO156F2Q
                                - Product Number: 5VU37AV
                                - UUID : 8C738DD9E78AAFA68B57037EDB4F56E6
                                The laptop is mine, but it's old and out of warranty. I just want to reset the BIOS password so I can reinstall Windows.
                                Please let me know if you can provide an SMC.bin or unlock instructions.
                                Thanks in advance!
                                  SMDFlea commented
                                  Editing a comment
                                  Thread merged.
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • Wutru
                                HP Elitebook 820 G4 BIOS repair assistance required
                                by Wutru
                                Hi guys,
                                If someone would be able to provide some expertise, I'd be very grateful.
                                BIOS Corruption - Cause
                                So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                09-06-2025, 10:32 AM
                              • STKR123
                                The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                by STKR123
                                Greetings badcaps community,
                                I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                I learned that desoldering...
                                10-29-2024, 06:03 AM
                              • clrscr
                                Need unlock bios hp elitebook 835 G11
                                by clrscr
                                please help me unlock bios password hp elitebook 835 G11
                                S/N: 5CG50434RD
                                thanks!...
                                06-04-2025, 09:38 PM
                              • Guest
                                Elitebook 850 G5 BIOS bricked
                                by Guest
                                I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                I assume the BIOS update failed, so I searched for the BIOS chip.
                                I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                Can the corrupted...
                                03-24-2025, 01:21 AM
