Asus X751MD cant verify bios after flash
  • pcrepai
    • Jul 2021
    • 46
    • Nederland
    Hello
    I have laptop ASUS F751M motherboard x751md rev2.0, diod from charger ligts up after I plug the charger, green diod also light up but ,after power it nothing happened, so I tried to flash bios chip, but I cant verify after, every time diffrent error, I tried few diffrent bios which I found on internet and here at forum, but nothing same result (cant verify after flash) can someone check oryginal bios bin ( attachment), please. Or is it possible that chip just died ???
    • 20966
    Re: Asus X751MD cant verify bios after flash
    what model is your programmer and software version, have you desoldered the chip
    • pcrepai
      • Jul 2021
      • 46
      • Nederland
      Ezp2010, ver.3.0, yes I desolder chip, also I flashed few other chip and it works fine. that why I'm curious what can goes wrong, I install win7 32bit to avoid any crashes no problems with any other chips only this one.
        • 20966
        If the chip is supported then its probably bad
        • pcrepai
          • Jul 2021
          • 46
          • Nederland
          ok thanks for the info I try to order new one.
          Regards
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • abhorsen
            Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
            by abhorsen
            Hey guys,
            Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
            Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
            Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
            07-06-2023, 10:22 AM
          • garretofriviaaaaa
            ASUS GL702V Bios flash
            by garretofriviaaaaa
            Hello all, so basically I have a bricked GL702V with no power except a single LED flash on the power button when it is pressed. Customer had tried to flash his bios with a USB and the GL702VM310 version of this laptop's bios. I've been scouring the web for a correct version of his bios but all the ones on the ASUS website are for GL702VM, GL702VT, GL702VS, or GL702VI with versions varying from 300-310. This specific laptop has nothing other than just the GL702V so I don't know which bios is compatible with it. I was planning on programming it with the CH341A programmer as soon as I found the correct...
            03-28-2024, 04:58 PM
